Insulation recommendations please!
Crooked_Caravan
PostPosted: Fri Oct 18, 2013 9:29 pm    Post subject: Insulation recommendations please! Reply with quote
Hello everyone!
I'm starting to research materials to insulate my caravan with – now, my boyfriend seems to think we are going to take the caravan to the Alps for a skiing holiday, so wants something of Arctic-spec. I'm a little more realistic~~~ (and I really REALLY like catered chalets) so whilst I want the caravan to be cosy and useable for a good portion of the year, I'm not planning to be mounting any expeditions to the polar regions in it!
What do you suggest?
Thanks!
PostPosted: Fri Oct 18, 2013 10:58 pm    Post subject: Reply with quote
Although I don't have a caravan, if I did I would use a urethane, foil backed sheet such as Kingspan. The thinnest you will find is 25mm and in house construction this would be about 100mm short of the regulation amount. In a caravan, with tight joins filled with fireproof expanding foam and foil taped I imagine this would make quite a difference.
Obviously I know that caravan people will have a standard approach to insulation so you can expect some contradiction here.
Have fun.
christine lowery
PostPosted: Sat Oct 19, 2013 10:12 am    Post subject: Reply with quote
hi
it depends on how much work you want to do to a caravan top off the range older vans have heavy foil insulation and modern vans expanded foam
the older vans are much better at retaining heat but if you have glass windows you will need heavy curtains with a thermal linning, and we are looking at the covers that motorhomes use on there glass windscreens
i think i could make them out of radiator foil
chris
Crooked_Caravan
PostPosted: Sat Oct 19, 2013 3:49 pm    Post subject: Reply with quote
Thanks – this is all really helpful information Smile
PostPosted: Sat Oct 19, 2013 6:45 pm    Post subject: Reply with quote
http://www.twistfix.co.uk/superquilt-multi-foil-insulation?uilang=1&gclid=CJSm9c65o7oCFZIPtAod-m8AJA
this is highly effective but still relatively thin insulation.
kev
david_rachel
PostPosted: Mon Oct 21, 2013 2:06 pm    Post subject: Reply with quote
I have posted this picture before; it's our caravan in the Alps in May earlier this year - it was our second time touring the Alps with a caravan and in the main we've stayed on designated sites (....out in the wilds only a couple of times).....the advantage with sites, anywhere in the world, is that you can plug in an oil filled, thermostatically controlled, electric radiator. Whilst there is an on-board thermostatically controlled gas heater in the Carlight I wouldn't want to leave it lit whilst asleep or away from the van.
David Rachel
1978 Carlight Casetta
1995 Lada Riva 1.5 Est Red
Fluffle-Valve
PostPosted: Tue Nov 19, 2013 9:49 pm    Post subject: Reply with quote
That'sa great photo... Great view...
Dalek63
PostPosted: Tue Nov 19, 2013 11:01 pm    Post subject: Reply with quote
I hope your Carlight has a good hand brake Shocked
OchAye
PostPosted: Thu Jan 09, 2014 3:00 pm    Post subject: Reply with quote
Love the PI estate.
david_rachel
PostPosted: Sat Jan 11, 2014 8:27 pm    Post subject: Reply with quote
Thanks! It was bought purely as a towcar for the Carlight!
David Rachel
