Morris 12/4 series 2 brake bleeding.
Spike2
PostPosted: Mon Jan 06, 2014 3:09 pm    Post subject: Morris 12/4 series 2 brake bleeding. Reply with quote
Can anyone help me please, I need to bleed the brakes on my car, do I need a special tool or adaptor to fit the wheel cylinder bleed nipple, as mine have a tapped hole down the centre, or is it just a case of pushing the bleed tube over the hex end of the nipple. Thanks.
bjacko
PostPosted: Wed Jan 08, 2014 5:01 am    Post subject: Brake Bleeding Reply with quote
Just push your tube over the nipple and bleed as normal.
The bleed nipple should be standard Lockheed P/N 2286 which is what most Morris cars have fitted.
