whiteshadow
Posted: Sun Mar 17, 2013 9:45 am Post subject: Fitting a Wooden body back! |
Hi,
I'm now at the point where I have to bolt the wooden body back to the steel chassis. Being wood I will obviously have to replace the packing to true things up, but what's the best method??
My plan was to do the following:
1) Pack the body so that it is level on the chassis
2) Refit the doors and adjust the packing to get correctly opening doors/gaps
3) Bolt down and check
Is this the right way?? |
rabbito
Joined: 21 Jan 2014 Posts: 15 Location: victoria australia
Posted: Mon Feb 03, 2014 12:21 pm Post subject: fitting body |
Hi whiteshadow I am currently doing an e83w ford as a woodie & as I have done a few vintage truck cab's for others what you are saying the method would be to fit your frame work sounds right as this is what I did on the truck cab's
rabbito |
whiteshadow
Posted: Mon Feb 03, 2014 12:37 pm Post subject: Bolting Down |
Great!
Thanks for the reply! |
