Strippers
PostPosted: Thu Mar 13, 2014 6:29 pm    Post subject: Strippers Reply with quote
No not that sort Wink
I'm going to sort the body out on the Z van in the spring, and want to remove the paint. I'm thinking of using something like a 80 grit pad on an angle grinder ?
Any thoughts
PostPosted: Thu Mar 13, 2014 6:36 pm    Post subject: Reply with quote
i have an air powered DA type sander that you can borrow?
Kev
petermeachem
PostPosted: Fri Mar 14, 2014 7:34 am    Post subject: Reply with quote
If you want to take all the paint off these do the job and don't damage the metal www.ebay.co.uk/itm/ABRACS-POLY-ABRASIVE-DISC-115mm-FOR-RUST-PAINT-REMOVAL-4-5-Qty-5-/111137128557 . Lot's people sell them
I used nitromors and a stanley knife paint peeler offer on the body to take quite a bit of the paint off. I think this is quicker and cuts down the huge amount of dust you get but nitromors is expensive
ka
PostPosted: Fri Mar 14, 2014 10:06 am    Post subject: Reply with quote
oh. paint stripper!
KA
Better three than four.
baconsdozen
PostPosted: Fri Mar 14, 2014 11:01 am    Post subject: Reply with quote
Damn,clicked for nothing.
PostPosted: Fri Mar 14, 2014 11:18 am    Post subject: Reply with quote
I've used those poly discs and they're pretty good, though noisy of course. Available either for your angle grinder, or with a spindle mount to go in an electric drill. You can get them in Halfords, I forget the price.
A recent test of paint strippers in Practical Classics, specifically to see how they work with car paint, suggests that either Rustins "Strypit" or Wickes own-brand paint and varnish remover are the two best, with the rest (including Nitromors) in recent formulations not being all that good. My experience with Nitromors certainly backs this up.
I have tried to find the Wickes own-brand stuff and never managed to, in fact the only one I could see in my local branch last time I went was the Polyfilla one, and I don't remember where that came in the test. I got some 'Strypit' off eBay and it gave variable results, though better than Nitromors. My car has been resprayed, though, and the original paint is putting up quite a fight no matter what I use (other than the poly disc). A test on another door which hasn't been resprayed gave much better results.
baconsdozen
PostPosted: Fri Mar 14, 2014 11:57 am    Post subject: Reply with quote
Recently a friend of mine paint stripped a coach. He'd done quite a few over the years but said that Nitromors didn't seem as effective these days as it used to be. I wonder if like a lot of other things that elf and safety have decided that certain chemicals and processes can't be used any more. I know for example that Dumdum is now banned as apparently it contains traces of asbestos.
petermeachem
PostPosted: Fri Mar 14, 2014 12:00 pm    Post subject: Reply with quote
I found nitromors ok on cellulose. It didn't bubble up but needed to be left for a little time to work, the paint peeled off pretty well. It is expensive though.
MikeG
PostPosted: Sat Mar 15, 2014 10:06 am    Post subject: Reply with quote
I have used a hot air gun stripper for wings ect on my 1936 Triumph Gloria.It works well without lots of dust.
PostPosted: Sat Mar 22, 2014 7:51 pm    Post subject: Reply with quote
Thanks for the replies Smile , Kev I have a da sander , but appreciate the offer Smile
Poly discs seem to be the favourite, I'll be stripping on steel panels an view on which grade of poly disc to use ?
petermeachem
PostPosted: Sat Mar 22, 2014 9:48 pm    Post subject: Reply with quote
I wasn't aware they were graded. They do wear down, I reckon I used 5 on a small car
