Posted: Sun Mar 30, 2014 6:15 pm Post subject: Windscreen Fitter in the NW |
I need the services of a windscreen fitter who can handle old fashioned screens and seals.
Has any1 got a contact who is local to LL14?
Kev |
Posted: Sun Mar 30, 2014 7:46 pm Post subject: |
Hi Kev
Can't help with the a name of a firm.....are you fitting with a new seal ? The reason that I ask is that when I did my MV course some 95 years ago ( just down the road from you in Chester) we had to fit a screen on an Astra as I remember, as part of the practical, 1/4" rope was order of the day with an ample supply of diluted washing up liquid; we were instructed that if a new seal was being fitted then no sealant should be used, as this is how cars came out of the factory...all very different to how modern screens are fitted.
Posted: Sun Mar 30, 2014 7:51 pm Post subject: |
Getting the screen into the opening isnt the issue dave, I cant get the chrome trim fitted after.
I have tried fitting the trim after installing the glass into the opening and also tried fitting the trim into the seal once the seal is on the glass but before the glass is installed into the car..no joy!
Found a mobile fitter in wrexham so I have emailed him, heres hoping.
Kev |
ka
Posted: Mon Mar 31, 2014 7:38 am Post subject: |
Hope you have found an 'old fashioned' fitter, and not the modern mastic gun operator.
The use of rope referred to in an earlier comment is used as part of the process.
Place the screen in the rubber.
Using rope, around 1/8" to 1/4", feed this rope into the screen rubber behind the screen.
Place the screen against the aperture, (get someone to hold the screen in place).
Work the rope out of the screen rubber, pulling the rubber seal in place and tucking trim in place (the trim is held in place by small clips)
Use the trimming tool to replace the chrome or plastic strip in the external gap.
use a lubricant (washing up liquid neat) where required.
If the screen is laminated, show great care, toughened do 'bend'
Best of luck, _________________ KA
Better three than four. |
Posted: Mon Mar 31, 2014 7:57 am Post subject: |
| ka wrote: | Hope you have found an 'old fashioned' fitter, and not the modern mastic gun operator.
Best of luck, |
well, he has a Picture of him doing a screen on an xk150 so assuming it is actually him id say he is old fashioned.
as for my screen, getting the glass in the opening is no bother, its the chrome trim thats the challenge.
Im sure there is a knack to it
kev |
Posted: Mon Mar 31, 2014 8:11 am Post subject: |
Just remembered ! MGB GT's have some really tricky chrome type inserts that are a pig to fit, if you are still stuck may be worth giving Mark a call at the Welsh MG Centre in Rhostyllen, see who they use.
Posted: Mon Mar 31, 2014 9:39 am Post subject: |
| ukdave2002 wrote: | Just remembered ! MGB GT's have some really tricky chrome type inserts that are a pig to fit, if you are still stuck may be worth giving Mark a call at the Welsh MG Centre in Rhostyllen, see who they use.
Ah, i will call in there on my way home
Cheers dave |
SV8Predator
Posted: Fri Apr 11, 2014 10:12 pm Post subject: |
Modern cars do not use 'mastic'.
But older 'classic' cars do. _________________ 2000 Jaguar XJ8 4.0 LWB
