rover P6 3500 series 2 auto
hornchurchmale
PostPosted: Mon Mar 03, 2014 10:59 pm    Post subject: rover P6 3500 series 2 auto Reply with quote
coming up to first year of ownership. still having issues with fuel. on sorn at moment and MOT about to expire..cash already expired..
fitted new plugs. electronic ignition. new fuel pump,filter, carb over hauled.
start with half throttle badly. runs badly until running 20-30 seconds.
then runs but only with nearly full choke at minimum 1500 rpms or shuts down. white smoke from exhaust I suspect is unburnt fuel.
paid far too much for it sigh. not sure where to go to sort running issues.
thinking of a colortune device maybe in each cylinder try and see if any are not burning or firing correctly.
looks like its not going to be on road much this year at this rate...checked carb fully before refitting, all gaskets new. floats good. new float level fuel valves fitted with rubber tips as supplied in kit.
no point putting pics up until damn thing gets out of my cramped garage.
shame a sit is my retirement hobby and so far only managed less than 130 miles in a year.
PostPosted: Mon Mar 03, 2014 11:14 pm    Post subject: Reply with quote
Does the P6 have the reserve swapover tap under the floor, like on the P5B? If so they can jam/gum up.
Have you tried a remote fuel feed straight into the pump, ie bypassing the main fuel line and tank, to see if the problems are with one of the latter?
BigJohn
PostPosted: Tue Mar 04, 2014 3:08 pm    Post subject: Reply with quote
Have you joined here:
http://www.classicroverforum.net/index.php?sid=fe05aa16b7fe06850595f709cbbb21d7
There is a wealth of P6 expertise to be tapped.
PostPosted: Tue Mar 04, 2014 11:51 pm    Post subject: Reply with quote
It could be stale petrol - white smoke is usually because it is drawing brake fluid in from a leaking servo. The changeover tap can block if P6's have them as can the pickup gauze in the tank
Rover P2
Morris Mini Traveller Mk2
PostPosted: Wed Mar 05, 2014 7:39 am    Post subject: Reply with quote
I had to replace the servo on my P5B for that reason.
PostPosted: Wed Mar 12, 2014 1:30 pm    Post subject: Reply with quote
I'd try Ricks suggestion and rig up a temporary fuel supply that will take the change over tap,pipes and filters out of the equation.
A Colortune will tell you if fuel is getting through but even though i sell them I find the plugs are almost as good as diagnosing faults in fuel quantity to each cylinder. I had problems on my V8 with the O rings on the starter (or choke) valves allowing excess fuel and air in. The engine would run but was far too rich at low revs with clouds of smoke.
hornchurchmale
PostPosted: Thu Mar 20, 2014 10:15 pm    Post subject: Update poor running. Reply with quote
Checked fuel system as all electrics are good. New fuel filter fitted with electric pump. Engine. Finally got to run around 800-900 revs when hot,
Then fuel was being ejected under car.
One carb overflowing.. Turns out to be sticking float...no new float or pivot pin available and a rework su hif6 costing approx£220 plus postage.. Prevents getting it sorted easily.
Managed using a gunson car balancer to get engine running almost smoothly..one carb needing no adjustment etc. other carb( one that float sticks in ) found to be almost impossible to adjust!
Looking at local breakers etc for a spare carb..( rocking horse poo comes to mind) so I can nick a float etc.
Might ask SU the conditioner if they are wiling to supply these parts only.. See if carb cab be set up. This is fairly certain the only thing stopping engine running well.
BigJohn
PostPosted: Thu Mar 20, 2014 10:21 pm    Post subject: Reply with quote
Have you given Nick Dunning a ring for a carb, you don't say whereabouts you're based.
http://www.farinap6.co.uk/about-us.php
hornchurchmale
PostPosted: Wed Mar 26, 2014 11:09 pm    Post subject: Carb issues. Reply with quote
Have fitted full refurb kit to carbs. Pump now packed up! Ggrrrr.
Will have to wait and see how it goes. Friend in local watering hole seems to know a guy who can set up twin carbs.. So hope lives.
Thanks to all who try to assist .summer on wY so need to get it rolling soon.
hornchurchmale
PostPosted: Thu May 01, 2014 8:07 pm    Post subject: Update p6 3500auto Reply with quote
update on rover.. rear brakes now o with new pads and discs. handbrake passes mot ( just) , checked engine vacuum at 21 mm hg so seems ok!
not rechecked vacuum unit yet but assured it works perfectly...still not happy with power as acceleration lack luster. ( wife beats me in her fiesta ggrr)
only issue other than lack of grunt is power drop off after stopping for a pint. think its likely petrol vapour issues. clears after couple of minutes driving all of a sudden ..like a button being pressed for turbo.
wonder if other rover p6 owners having or had such issues?
