1936 Morris 8, my first restoration
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Bob T
PostPosted: Mon Jan 13, 2014 10:49 pm    Post subject: Reply with quote
A couple of days ago I fired up the Morris after several months of inactivity. It took a few turns bit started ok, I then tried to drive it and as soon as I pressed the throttle there was no power!
I checked all thye obvious things to no avail and so today I decided to strip the carb. My car has a air silencer as opposed to a air filter. I disconected the sliencer from the carb first.
I noticed something odd looking in the silencer link to the carb, on closer examination I found it was a cob nut. I proceeded to remove 29 of them from the air intake !!!
Problem solved. All I need to do now is find an effective way of getting rid of the mice!
TribalElder
PostPosted: Tue Jan 14, 2014 6:29 am    Post subject: Reply with quote
Rolling Eyes He he he, that's funny. Can you put fine mesh over the air intake to keep the vermin out? My Morris 8 Ser. E has the oil-bath type filter on top. Cool
Ian from Oz
It's hard to run like an Emu
When you are girt by Numbats
Bob T
PostPosted: Mon Jun 09, 2014 6:02 pm    Post subject: Reply with quote
Time for an update.
AS a result of a trip to the autojumble at Buealiey my car is now sporting two as new front side lights of the correct type and two new (pattern) pork pie rear lights. The original Lucas rear lights are in good condition and just need a paint, I will get round to that at some time and will probably reinstate the originals.
Also I have just had two front headlamp shells painted, they are undented and without rust, and so I just need to swap the reflectors over and my car will be looking good. I will post some pics soon.
Since Jan I have been using my car less and less as intermittent running problems ahe persisted and worsened and I had not been avble to solve the problem until now !!!!!!
I have just fitted a new 123 ignition sysytem, this is a distributor replacement, but it is full electronic without points, condenser, bob weights and springs. But it does have 16 advance curve settings. It was simple to fit and does not look too out of place, again I will post some pics.
The upshot is that starting is now much improved, it ticks over evenly and accelerates (if that is what you call it !) much better and pulls up hills better too.
I am very impressed with the product, I have done more miles in the last two days than in the last two months, it is a joy to drive.
THe system is available for nearly all cars, it was £209 plus vat, which compared to a quote of £185 plus vat to rebuild the old dizzy seems good value in light of the performance improvement.
Regards to all
Bob T
TribalElder
PostPosted: Tue Jun 10, 2014 1:45 am    Post subject: Reply with quote
Hi Bob. I went a different way with my dizzy. I just replaced the points with a "Hall Effect" Electronic ignition and removed the condensor. It was only $75 delivered from the UK to Oz. Been very impressed with it, utterly reliable and I get to keep the original Dizzy in place for originality.
Original
sensor and ring fitted
Rotor back on
Finished job, showing the black and the white wires added
Mine is a '46 Series E Pos Earth.
Ian from Oz
PostPosted: Tue Jun 10, 2014 9:47 am    Post subject: Reply with quote
Ive just replaced the ancient Lucas electronic system on the singer for a new accuspark unit (started as a temp fix until a NOS distributor of the correct flavor turns up).
Must say I am chuffed with it, best £60 spent to date.
In the long run I aim to fit the NOS distributor with an electronic aftermarket system installed. This should give me both reliability and the correct advance/retard that the car needs (not that it can be far off now as the car starts and drives superbly well)
Kev
Bob T
PostPosted: Tue Jun 10, 2014 12:25 pm    Post subject: Reply with quote
I had an accuspark electronic system fitted to the old distributor, but it still ran rough.
The difference with the 123 system is that it also does away with the advance/retard mechanical mechanism. The bob weights and springs on my dizzy were past their best and there was wear on the shaft etc.
It has done the job for me, and if it means I get to use the car more often that is what counts.
I can always replace the original system if needed.
Bob
PostPosted: Tue Jun 10, 2014 12:31 pm    Post subject: Reply with quote
Bob
I bought the complete new distributor from accuspark Bob, it was a replacement for the 25D lucas item but the advance/retard would be a compromise due to being somewhere near for all engines. The idea behind using the NOS Lucas item with the electronic bits fitted is to have the correct weights and springs.
I do like those 123 set ups though.
Kev
goneps
PostPosted: Tue Jun 10, 2014 11:50 pm    Post subject: Reply with quote
Bob,
It would be interesting to have pictures of your 123 distributor to see how similar or otherwise it is to the original.
Richard
Rosco663
PostPosted: Wed Jun 11, 2014 7:10 am    Post subject: Reply with quote
Here is a link for more info. Looks like a regular dizzy - a bit too shiney for me
http://www.123ignition.com.au/
I don't reckon I can justify the AUD 500 at this stage though
Rosco
bjacko
PostPosted: Thu Jun 19, 2014 7:19 am    Post subject: Morris 8 Air Silencer Reply with quote
I fitted a small round air filter on the right hand end of the air silencer. This keeps out dust and everything else that may wear the cylinder bores.
peterd60
PostPosted: Wed Jul 16, 2014 8:51 pm    Post subject: Reply with quote
Can't wait for mine to be at this stage, struggling to take the body off at the minute, did you make the sills yourself?
Bob T
PostPosted: Mon Jul 21, 2014 8:47 pm    Post subject: Reply with quote
HI Peter,
I bought the sills from a company in Nottingham (I think it was Vintage Carriages), that said they still needed a lot of fettling to get them to fit, but they were a good starting point.
Good luck, I look forward to watching your progress.
My car is by and large fairly well sorted now and a joy to drive, I am sure your efforts will be rewarded.
Bob T
Bob T
PostPosted: Mon Aug 04, 2014 4:44 pm    Post subject: Reply with quote
I have been busy with other projects (1969 MGB Roadster) recently, but too the Morris 8 to Helmingham Hall show yesterday, it is about a 70 mile round trip for me and the first proper test since installing the 123 ignition system. I can report that the car went well and was a pleasure to drive.
Bob T
PostPosted: Fri Aug 08, 2014 12:55 pm    Post subject: Reply with quote
I did say that I would post some pics of the new 123 ignition system and some pics of my finally restored lights. So here goes!
As for the dizzy, if the cap was black most people would never notice it was not original unless you were specifically looking at the dizzy.
BUt for me the point is that it works really well and the car is a pleasure to drive.
TribalElder
PostPosted: Fri Aug 08, 2014 1:10 pm    Post subject: Reply with quote
Looking good Very Happy
Ian from Oz
Page 8 of 9
