Posted: Thu Jun 26, 2014 8:00 am Post subject: Advice on cleaning spade connectors |
I am looking for a "magic bullet" way to remove long term verdigris and general oxidation from the connectors on my wiring loom. It's a '60's Fiat so I want to overcome the "dodgy electrics" reputation.
I am aware of electrical contact spray and that I can physically clean them with a small wire brush or fine wet and dry but the female spades are awkward.
The internet suggests dipping in Coca-Cola or vinegar; I don't have the former and tests with vinegar are inconclusive.
Any suggestions will be welcomed and tried if they are new to me. |
Posted: Thu Jun 26, 2014 8:52 am Post subject: |
Any bluish sulphated deposits can be easily removed with a water solution of washing soda, Magical on battery terminals!
Dirt is another matter and generally needs abrasion. Acids tend to damage other things though phosphoric acid may help (Coka Cola contains phosphoric acid, but very diluted hence slow reaction).
Whatever is tried - wash off with clean water afterwards.
Many rust removers, like Jenolite, contain phosphoric acid. That might be worth a try?
Posted: Thu Jun 26, 2014 10:11 am Post subject: |
| Thanks Jim. Off to try that now. |
Posted: Thu Jun 26, 2014 10:24 am Post subject: |
Did this exercise last winter on the Singer, I had some rigid but thin emery cloth which worked well on the female spades, fine wet n dry on everything else.
Once clean I applied some Contralube to prevent future corrosion
http://contralube.com/contralube-770/
Kev |
Posted: Thu Jun 26, 2014 12:32 pm Post subject: |
| kevin2306 wrote: | Did this exercise last winter on the Singer, I had some rigid but thin emery cloth which worked well on the female spades, fine wet n dry on everything else.
Kev |
Having failed on all liquid dips at my disposal that might have worked I will be doing as you did Kevin. |
Posted: Sat Jun 28, 2014 8:56 am Post subject: |
Ive been thinking about this issue some more.
I used abrasion to remove any corrosion found on the connectors followed up by the application of contralube prior to reconnection. I stayed clear of using any cleaners as I was worried they may get into the loom and cause further corrosion/degradation.
Kev |
