Chrome
classicclara
PostPosted: Wed Oct 22, 2014 11:48 am    Post subject: Chrome Reply with quote
The chrome (bumpers, door handles etc) on our Rover P3 1949 need re-doing. Anyone recommend anywhere that does a good job on re-chroming? Preferably in the Suffolk/Norfolk/Essex area.
Thanks.
Rover P4, 1964, Clara.
Rover P3, 1949, Chester.
Old Wrench
PostPosted: Wed Oct 22, 2014 7:24 pm    Post subject: Reply with quote
Hmm no takers, thus far, Clara. See if I can help a bit.
Doesn't actually matter who you go to, as I believe those parts were made from solid brass castings: (Except the bumpers, they will be mild steel), whereas later on, for cheapness, trim and door handles, light surrounds etc, were made from Mazak, a very cheap alloy of mainly Zinc with small amounts of Alluminium and Copper.
Over time (particularly when exposed to water): some types had lead in the mix, too. Over time they suffered from severe eruptions of "Pin Holes".
However, with brass parts they can be acid dipped (Muriatic Acid), then polished and cleaned to remove any grease; then Nickel plated; finally
Chromium Plated.
Here is a very good short description: You will note these boys also lay down a bed of copper.
http://www.verneschromeplating.com/triple-chrome-plating.html
Advice? Check around locally and county and quiz the "Experts" to make sure they are going to carry out a proper process.
Well, apart from that, did you enjoy the play, Mrs Lincoln?
PostPosted: Wed Oct 22, 2014 10:14 pm    Post subject: Reply with quote
You can try Derby Plating but the door handles are in fact Mazak and will shrink through the deep polishing necessary to remove the craters which may look like a pinhole from the top but open out to a cavern - some have filled them with solder
Rover P2
Morris Mini Traveller Mk2
Old Wrench
PostPosted: Thu Oct 23, 2014 6:11 pm    Post subject: Reply with quote
Clara:
If the door handles and indeed any other parts are Mazak, then try this firm:
http://www.chromerestorationspecialist.co.uk/projects/mazak-repair/
Another reason I love older Jags: brass.
PostPosted: Mon Oct 27, 2014 9:57 pm    Post subject: Reply with quote
My Jaguar Mark VII (1953) will need its door handles, boot handles and outside strips rechromed. Would these be brass as well? How can you see if it is brass or Mazak?
I made a deal with Harrington with the bumpers. The car will have stainless steel bumpers. A bit different to chrome I know but much, much better than the originals.
Old Wrench
PostPosted: Tue Nov 11, 2014 5:35 pm    Post subject: Reply with quote
Basically, badhuis, by the weight. brass is far heavier (and considerably more expensive!).
If in doubt, scurf of plating where it does not matter, say underneath the casting.
