Winter plans
PostPosted: Wed Nov 19, 2014 5:15 pm    Post subject: Winter plans Reply with quote
Do you have any interesting jobs lined up to tackle on your motor(s) over the winter? I still hope to do a head swap on big Dodge at some point, other than that I'll just be hoping to finish a few odd jobs that I started many months ago Smile
PostPosted: Wed Nov 19, 2014 5:23 pm    Post subject: Reply with quote
Apart from giving the Singer a thorough service it's pretty much good to go for next season.
My time will be taken recommissioning this:
Kev
bob2
PostPosted: Thu Nov 20, 2014 8:42 am    Post subject: Reply with quote
Yes my plans include using them whenever we have a nice and sunny weekend.
Other than that probably a good service to each and every one of them and maybe do some work (which I have been procrastinating for too long) on the surf blue mini.
JohnDale
PostPosted: Thu Nov 20, 2014 11:39 am    Post subject: Reply with quote
My plans are not to do anything car wise(except emergencies) & devote more time to amateur radio without going outside(hibernation). Will have a new rotator fitted before the bad(instead of just rotten) weather comes so that I hopefully won't need to do anything & can play to my hearts content,cheers,JD.
1976 Ford Granada Ghia.
Fatbloke
PostPosted: Thu Nov 20, 2014 12:09 pm    Post subject: Reply with quote
I plan to restore the front seats on my 13/60 and try and get the heater working! and maybe bodge some repairs on the hood frame.
Father in law will help with the bodging and as he is a retired engineer and perfectionist they will be top quality bodges. they just won't won't necessarily use original parts or even look the same underneath. Can't afford a descent 2nd frame and replacement parts are just not available.
Sorry! Embarassed
Mike,
A Fatbloke in a Herald.
norustplease
PostPosted: Thu Nov 20, 2014 5:44 pm    Post subject: Reply with quote
I need to do some welding around the spare wheel well of the Volvo at some point. Not a massive job in itself, but I will need to remove the fuel tank to avoid blowing it and myself sky high and will probably pop off the rear wing in that corner as well, for good measure.
1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV
PostPosted: Fri Nov 21, 2014 11:32 am    Post subject: Reply with quote
I intend to build the wooden platform body for my Commer lorry, as usual with these things though it won't happen to plan!
BigJohn
PostPosted: Fri Nov 21, 2014 1:14 pm    Post subject: Reply with quote
Fit new carpets, seats, seat belt. New wheels, track control arms, drop rear suspension 1". Fit new carb, turn dizzy 180 deg. to where it should be, and new engine mounts. (Finished by lunch, sometime in April)
goneps
PostPosted: Fri Nov 21, 2014 10:17 pm    Post subject: Reply with quote
We're actually coming into summer here, of course, but the jobs don't go away because of that. So...
1. Replace the exceptionally durable but badly-cut Van Dyck carpet, and minor mods to the floorboards to be more original.
2. Make and install the frame around the semaphore indicators, just aft of the door posts, omitted by the 'restorer'. Then re-trim the side panels to more closely match the seats.
PostPosted: Sat Nov 22, 2014 10:30 am    Post subject: Reply with quote
I have 4 Morris 8 doors and a boot that all have rusty bottoms and frames to repair..... I hope it doesn't take me all winter Shocked
The skins wont be so difficult, but the frames are more tricky: bends and pressings to recreate!
welder
PostPosted: Sun Nov 23, 2014 1:02 am    Post subject: Reply with quote
I'm going fishing for Perch and Barbel.
I'll mess with car when it gets warmer.
Ian
Riley1489
PostPosted: Sun Nov 23, 2014 9:37 am    Post subject: Reply with quote
I've been instructed/told/ to get the heater working properly in my 1960 Riley 1.5. Can't say I disagree as we plan to go to a New Year's Day event down at Haselbury Mill near Crewkerne and it can get a bit chilly on the way down with just a cold draught blowing round your legs.
Graham
(Rust never sleeps)
john-saab
PostPosted: Mon Dec 22, 2014 6:01 pm    Post subject: Reply with quote
We now live quite close to Haselbury Mill so might see you there!
Rust Junky & oil addict.
Riley1489
PostPosted: Mon Dec 22, 2014 6:37 pm    Post subject: Reply with quote
I'll look out for your Saab. My Riley 1.5 is Yukon Grey. Just hoping for some decent i.e. dry weather now. Fingers crossed.
Graham
(Rust never sleeps)
PostPosted: Tue Dec 23, 2014 2:25 pm    Post subject: Reply with quote
Have heard about the New Years day meet at Haselbury Mill. Think we might pop down for an hour or two but not sure if it will be in our Hillman. Its about 25 miles from us so its weather and children dependant!!
