buzzy bee Guest
Posted: Wed Aug 29, 2007 4:59 pm Post subject: Line shafts |
How do you set a line shaft up, obviously only a small one, but one powered by a stationary engine perhaps?
Anyone ever done anything with shafts, slip pully's and the rest of it?
Penman Guest
Uncle Joe Guest
Posted: Sun Sep 02, 2007 10:23 am Post subject: |
Buzzy, what kind of belts are you going to use from your line shaft, flat or Vee?
UJ |
buzzy bee Guest
Posted: Sun Sep 02, 2007 11:38 am Post subject: |
I was thinking of flat belting, but I am only thinking about it at the moment, not actually making it. He he
I like the look of that mill, I may go over there as I have an interest in mills, thasnks for the link!
Uncle Joe Guest
Posted: Sun Sep 02, 2007 12:08 pm Post subject: |
Buzzy, if you are thinking of flat belting, then you have to make sure that the pulleys are crowned, and that shafts are something like parallel.
Why not visit Trencherfield instead?
UJ |
Penman Guest
Posted: Thu Sep 06, 2007 5:15 pm Post subject: |
Just been to Manchester Museum of Science and Industry.
Found these a full size Line shaft work shop and a working model of one as well.
buzzy bee Guest
Posted: Thu Sep 06, 2007 5:35 pm Post subject: |
Where abouts in Manchester is that?
I will probably be spending alot of time in Manchester Shortly, so may call in there!
Thanks for the pictures, and for remembering this thread!
Penman Guest
Posted: Fri Sep 07, 2007 12:21 am Post subject: |
Liverpool Rd in the Castlefield area.
http://www.msim.org.uk/
From the top floor in one building you can also look down into Coronation St.
Part of the site is the original station on the Liverpool and Manchester Railway.
If you were coming in from Cheshire by train, or tram using Alty as a park and ride, it is relatively close to Tram, or Deansgate Rly., stations. |
