CAN ANYONE IDENTIFY THESE HEADLAMP LENSES?
Ronniej
PostPosted: Fri Oct 23, 2015 1:54 pm    Post subject: CAN ANYONE IDENTIFY THESE HEADLAMP LENSES? Reply with quote
I am helping a friend restore a 1928 Triumph Super 7.
His project is nearing completion and we are about to fit the lights.
We have the original headlamp shells which are of Lucas manufacture but of a type neither of us have seen before.
Unfortunately the lenses are missing and we hope to use the ones pictured which were among a box of spares I had in my garage.
It should be possible to fit them although we may have to grind a little off the circumference to achieve this.
You will see from the picture that they are lightly frosted with a clear diamond in the centre. They are 6.75" in diameter and have no maker's name.
I have two questions:
1. Can anyone identify what car these would have been fitted to or who the maker is?
2. The diamond is longer than it is wide; can anyone advise how they should be fitted? (i.e. should the long side be vertical or horizontal?)
Ronnie
[url][/url][img][/img][img][/img][img][/img]
PostPosted: Fri Oct 23, 2015 3:35 pm    Post subject: Reply with quote
I don't recognise them, but the diamond proportions look about right for the Riley logo; early Nines usually had Rotax headlamps, but did they have special 'Riley' lenses?
PostPosted: Fri Oct 23, 2015 3:59 pm    Post subject: Reply with quote
The Renault used the diamond as well.
It is only late C20th when they cut the points off.
In Rick's 1930s picture album one of the Rileys has a Diamond in the centre of the h/ls BUT I can't make out if it is on the glass or on the 3 legged metal spider behind the glass.
Ronniej
PostPosted: Fri Oct 23, 2015 4:39 pm    Post subject: Reply with quote
Thanks for that.
It had occurred to me that the diamond was similar to the shape of the Riley badge.
I had not thought about Renault but that is also similar.
The issue we would like to resolve is how the diamond is positioned within the lights.
Should the long edge be horizontal or vertical?
Ronnie
PostPosted: Fri Oct 23, 2015 5:38 pm    Post subject: Reply with quote
Would love to see some pics of the finished car, can't be many around now.
Ronniej
PostPosted: Sun Oct 25, 2015 10:50 am    Post subject: Reply with quote
This little car was put into storage in 1965 while the (then) owner finished another project. It had been his firm intention to proceed with it but other projects arose and then his health failed.
My friend purchased it from his widow almost three years ago and we spent an enjoyable weekend extracting it from its storage. This was no simple matter as other buildings had been erected over the intervening years.
This would probably be called a "barn find" if offered on E-Bay as anything that has been in a shed for more than a few weeks is often given this description.
I hesitate to use this expression in this case as the car was never lost but simply left untouched for almost 50 years.
When finally extracted and brought to the workshop a detailed examination was made. We were impressed by the build standard of what was essentially a cheap mass-market car. It has 4 wheel hydraulic brakes which must have been unusual for even high end cars of the period.
The Pre-40 Triumph Club, who have been an excellent source of advice and parts, were most interested to hear of the car as it has a boat-tail body and very few of this variant have survived. On that subject, the rear end of the body was heavily corroded and this was looking very problematic. However, in a moment of inspiration, my pal noticed the shape closely matched the bulbous top of a Minor 1000 bonnet and a section was cut from a scrap one.
During the restoration he has tried to keep everything original but there are small areas where we had to be pragmatic and use what was available.
Where this had to be done care was taken to ensure the parts were in period.
I have attached a few photos of the car as found and the subsequent progress made. Photobucket is quite difficult to use so I have limited these.
If anyone is particularly interested I will be happy to e-mail more if they care to send me a PM.
Meantime, the question that kicked off this post still remains unanswered: does anyone know how the diamond on the headlamp lenses should be aligned? [img][/img]
[img] [/img] [img][/img][img][img] http://i498.photobucket.com/albums/rr349/morristourer/RONNIE-PC/TRIUMPH%20RESTORATION/FULL%20VIEW.jpg[/img] [/img] [img] [/img] [img] [/img] [img] [/img] [img][/img] [img] [/img]
PostPosted: Sun Oct 25, 2015 1:52 pm    Post subject: Reply with quote
I am not sure that these lenses were ever fitted to car headlamps. The frosting gives no direction and would diffuse the light over 360 deg with slightly more light in the centre.
Perhaps they were from Marine or Theatre fitting ?
goneps
PostPosted: Mon Oct 26, 2015 12:05 am    Post subject: Reply with quote
In the past there has been some discussion on the topic of 'frosted' lenses in Morris Register circles. Series 2 Eights (and a great many other cars and
motorcycles of the period) were equipped with what appear at a casual glance to be frosted glass lenses, when in fact they're patented
Lucas Difusa lenses.
Whereas an ordinary frosted glass would indeed simply spread the light, the Difusa has in intricate pattern that, remarkably, does an excellent job of
directing the beam, presumably giving a broader spread than the earlier vertically fluted lenses that give a very concentrated beam when used with
the original type of bulb with V-shaped filaments.
Richard
PostPosted: Mon Oct 26, 2015 12:22 pm    Post subject: Reply with quote
The Lucas P100 headlamps as fitted to the 1946-48 Jaguars and Austin Sheerline had frosted glass with a clear 'bullseye' centre.
Art
