We need a bigger boat.
PostPosted: Thu Nov 19, 2015 2:13 pm    Post subject: We need a bigger boat. Reply with quote
I found the video entertaining.
http://www.bbc.com/future/story/20151113-this-is-why-people-cut-cruise-ships-in-half
PostPosted: Thu Nov 19, 2015 2:31 pm    Post subject: Reply with quote
Amazing what goes on eh!?
PostPosted: Thu Nov 19, 2015 3:57 pm    Post subject: Reply with quote
You need to look out for some of these cut and shut jobs Wink
minormatt
PostPosted: Thu Nov 19, 2015 5:37 pm    Post subject: Reply with quote
Did you know that Nuclear Subs are refulled by cutting a hole in the pressure hull refulling and welding it back up again?
D4B
PostPosted: Thu Nov 19, 2015 6:03 pm    Post subject: Reply with quote
Not a job for the feint hearted! Hope they are paid very well Shocked
PostPosted: Thu Nov 19, 2015 6:52 pm    Post subject: Reply with quote
I thought that they didn't need refueling. Doesn't the fuel last for so long the sub would be well past its "use by" date. ?
emmerson
PostPosted: Thu Nov 19, 2015 10:25 pm    Post subject: Reply with quote
And you can't even see the join!!!!!!!!!!!!
PostPosted: Thu Nov 19, 2015 11:26 pm    Post subject: Reply with quote
Bondo and paint. Works wonders
ka
PostPosted: Fri Nov 20, 2015 8:40 am    Post subject: Reply with quote
I accept this is the other end of the spectrum, but one of our inter-island ferries, 'The Hoy Head', no clues as to where it sailed to, was cut across around the 1/3, 2/3 mark, and an extra lump welded in the middle to extend it.
KA
Better three than four.
PostPosted: Fri Nov 20, 2015 12:09 pm    Post subject: Reply with quote
https://en.wikipedia.org/wiki/MV_Hoy_Head
PostPosted: Fri Nov 20, 2015 3:46 pm    Post subject: Reply with quote
Certainly not the only ship to have a large section inserted in its centre but great video.
PostPosted: Fri Nov 20, 2015 9:22 pm    Post subject: Reply with quote
This is part of an article I wrote back in 2010 criticising the Dept for Transport and DSA
Quote:
I have recently been re-reading the autobiography of the engineer and novelist Nevil Shute. “Slide Rule” published by Heinman in hardback or Pan in paperback.
He was involved in the construction of the private venture airship R100 which was built at Howden, Yorkshire at the same time as the government was building the ill-fated R101 at Cardington.
The previous British airships included the Air Ministry built R38 which had crashed in the Humber estuary.
During the enquiry into this crash it had transpired that the engineers had done no calculation of the aerodynamic forces acting on the frame during flight, the airship had in fact been built by copying the sizes of the girders on the wartime German Zeppelins.
None of the “engineers” responsible for this earlier disaster were disciplined and were subsequently to be the builders/designers of the R101.
The R101 initially failed to reach it’s designed range/load parameters and shortly before it’s final trial flights had to have an additional bay inserted in to the central section along with another gasbag, because of political considerations it was then decided that it would have to undertake it’s long flight to India without actually undergoing the full complement of trial flights which had been previously planned.
But this mattered not as the organisation which issued airworthiness certificates was the same as that which built it.
Nevil Shute writes “ A man’s own experiences determine his opinions, of necessity.
I was 31 yrs of old at the time of the R101 disaster, and my first close contact with senior civil servants and politicians at work was in the field of airships, where I watched them produce disaster. That experience still (written some 38 yrs later) colours much of my thinking. I am very willing to recognize the good in many men of these two classes, but a politician or a civil servant is still to me an arrogant fool till he is proved otherwise”
“Either these men at the Air Ministry were extraordinarily stupid, or they appreciated that quite abnormal and unjustifiable risks were being taken with the R101.
If the latter be true, then they failed to speak up against the Minister because they were afraid. If just one of them had said ‘This thing is wrong, and i will be no party to it, I’m sorry gentlemen but if you do this , I’m resigning’- if that had happened on any one of a dozen or so opportunities, the disaster would almost certainly have been averted.
It was not said because the men in question put their jobs before their duty”
Why, you might say, do I go to such lengths to tell you about these events and opinions?
The Air Ministry as was then, is nowadays part of the same organisation which has responsibility for all transport matters in the UK, and is thus in charge of the DSA, which let’s face it is only an arm’s length way of government trying to disavow itself of responsibility for driving standards.
Why do you think the DSA’s training centre is on part of the original Cardington airship base?
It is because the site still belonged to the Ministry at the time the training centre was moved from Hendon.
Does the same attitude to research and statistics, ignore what doesn’t fit with pre-conceived ideas, still persist in the higher levels of the civil service and government.?
PostPosted: Fri Nov 20, 2015 9:43 pm    Post subject: Reply with quote
Nevil Shute's "Slide Rule" is certainly a good read. I just re-read it again a couple of months ago.
PostPosted: Sat Nov 21, 2015 12:52 am    Post subject: Reply with quote
http://www.airshipsonline.com/airships/r101/Crash/R101_Crash.htm
