Posted: Fri Nov 27, 2015 8:58 pm Post subject: Car lifts |
Has / does any1 here use a 2 or 4 post car lift as storage for a car in their garage?
I'm struggling to store a lovely eunos I own, don't really want to sell so considering forking out for a lift so I can stack my 2 cars the the garage.
Kev |
christine lowery
Posted: Fri Nov 27, 2015 9:32 pm Post subject: |
sounds like a great space saving idea as well as a great asset when you need that b it of high't to work on your car there a a few bits online when you google the idea go for it
Christine  |
Posted: Fri Nov 27, 2015 11:59 pm Post subject: |
There are a couple of things one should consider, the most important is headroom
One can either make accurate calculations, vector the lift corners, and provide a roof with sufficient headroom
or........ option 2
draw a chalk line around the hole and extend the roof as required. |
Posted: Sat Nov 28, 2015 9:17 am Post subject: |
peterwpg wrote: | There are a couple of things one should consider, the most important is headroom
or........ option 2
Head room isn't an issue, neither is the power supply. Just need to convince myself it's a good idea!
Kev |
ka
Posted: Sun Nov 29, 2015 9:02 am Post subject: |
Car lifts are an excellent idea to get to the underside, and increase storage.
The choice between two post and four post is a little more complex, I have worked under both.
The two-poster requires sound floors to locate the lift, and good depth of concrete to drill into to mount the locating bolts. A four poster is inherently more stable, and does not require the depth of fixings a two-poster needs.
There are also two types of mechanics to raise the arms, chain or hydraulic.
Hydraulics are obvious, but the chain type rotates a screw the length of the vertical arm, and moves a threaded boss up and down, and therefore the arm. Simpler and cheaper than hyberbolics. _________________ KA
Better three than four. |
Posted: Sun Nov 29, 2015 11:31 am Post subject: |
The screw ones are fine....unless they jam when fully raised. What a bother getting it back down. _________________ The Clan Chieftain |
Posted: Sun Nov 29, 2015 11:48 am Post subject: |
No problems storing a car on the ramp with another below.
 _________________ ROVER
One of Britain's Fine Cars |
Joined: 30 Apr 2013 Posts: 4173 Location: The Somerset Levels
Posted: Sun Nov 29, 2015 12:25 pm Post subject: |
I have the same storage issues. My unit is very tall but narrow, the only thing stopping installing a lift is cost. _________________ Various Rootes Vehicles. |
ka
Posted: Mon Nov 30, 2015 9:22 am Post subject: |
Some years ago, we stayed in a Hotel in Aachan, North Germany, and the car park beneath the Hotel had it's capacity doubled by the use of cassette type parking places, where they moved up and down as a unit, with a car on the upper, and lower levels. The main problem we encountered was the lack of headroom, as we were on a motorcycle, and the clearance between the screen, and me as a rider was quite tight. _________________ KA
