What are Autolube plates?
PostPosted: Thu Dec 03, 2015 1:19 am    Post subject: What are Autolube plates? Reply with quote
In an advertisement for a MG PB project, there is mention that "even the Autolube plates are still with the car".
I am sure you chaps will know what these might be but in over 40 years of playing with old cars I have never heard of them...?
http://www.carandclassic.co.uk/car/C641801
PostPosted: Thu Dec 03, 2015 9:34 am    Post subject: Reply with quote
I've only come across the term autolube in connection with two-stroke engines, referring to, I think, a pre-mixed petrol/oil mixture. I didn't realise that pre-war MGs were ever fitted with two-stroke engines... Embarassed
Dipster
PostPosted: Thu Dec 03, 2015 9:46 am    Post subject: Reply with quote
Perhaps the advertiser would know...... You could ask him.
PostPosted: Thu Dec 03, 2015 10:02 am    Post subject: Reply with quote
Sounds like some sort of lubrication system for oiling kingpins shackles and other joints, similar to what Rover fitted to their cars
ROVER
One of Britain's Fine Cars
PostPosted: Thu Dec 03, 2015 10:06 am    Post subject: Reply with quote
Thanks.
My guess is that it's a mistake.
The project looks too expensive for what it is so I will pass on it.
PostPosted: Thu Dec 03, 2015 6:27 pm    Post subject: Reply with quote
Autolube is a bit of a misnomer as it requires someone to operate a grease gun. It just places the nipples in a more convenient place. The MGs had a plate on each side.
PostPosted: Thu Dec 03, 2015 7:16 pm    Post subject: Reply with quote
Brilliant! Thanks Peter. I feel as if I have been living in a cave all my life.
Do you know if the system was reliable? and have many owners removed them?
PostPosted: Thu Dec 03, 2015 9:01 pm    Post subject: Reply with quote
Hi Ray,
I think they tended to clog up. Perhaps they were intended for oil rather than grease lubrication. I think most restored cars have the system just because it was original equipment.
PostPosted: Thu Dec 03, 2015 9:15 pm    Post subject: Reply with quote
Thanks Peter. Yet again this forum is an education.
PostPosted: Thu Dec 03, 2015 9:29 pm    Post subject: Reply with quote
peter scott wrote:
Hi Ray,
It's a bit hard to make out, but the 3 grease things are labelled D E & F.
D = rear brake cable
E = front -"-
F = front & rear springs & the brake cross-shaft.
Instructions below refer to using gear oil every something-or-other miles.
I wonder where the ABC pipes went.
Edited to add - ABC were on the other side, same cables & springs plus the steering box. I still can't read the mileage! 500?
2002 MINI Cooper 'S'
PostPosted: Thu Dec 03, 2015 10:16 pm    Post subject: Reply with quote
I think it's a lovely feature considering the Midget was a reasonably priced sports car. I have suggested swapping my Dodge for a friends TC project but I think the noisy engine (suspected bent con rod) has put him off. I don't recall seeing these 'autolube' plates though...perhaps they were discarded long ago or else hiding in a box of bits Laughing
I wished I had sold the Dodge yesterday when an unspoilt PB came on the market at a knock down price...it had gone by this morning! Rolling Eyes
goneps
PostPosted: Fri Dec 04, 2015 12:10 am    Post subject: Reply with quote
500 seems most likely since that's the chassis lubrication interval specified for pre-war Morris cars. In the case of these cheaper models SAE140 oil was dispensed from the Enots oil gun supplied in the toolkit.
As I recall, Autolube was the name coined by Yamaha for their two-stroke lubrication system introduced around the mid-'sixties. This did away with the tedious and haphazard business of putting oil in the petrol; instead the oil went into a separate tank and was pumped to critical points in the engine.
Suzuki had a similar system, but blowed if I can remember what they called it.
The early part of my chequered career was spent in the printing trade, and the German Roland litho machines I ran featured an extensive central lubrication system, operated by the push of a button.
Richard
PostPosted: Fri Dec 04, 2015 12:19 am    Post subject: Reply with quote
................ I don't recall seeing these 'autolube' plates though...perhaps they were discarded long ago or else hiding in a box of bits Laughing .............:
I assume the Autolube system was only on the early cable-braked cars. My 2nd car was a 1934 P-type, but with hydraulic Morris axles & a Ford engine.
PostPosted: Fri Dec 04, 2015 12:54 am    Post subject: Reply with quote
That makes sense, Mike.
At this rate I will soon have a half decent education! Laughing
alanb
PostPosted: Fri Dec 04, 2015 4:03 pm    Post subject: Reply with quote
[I assume the Autolube system was only on the early cable-braked cars. My 2nd car was a 1934 P-type, but with hydraulic Morris axles & a Ford engine.]
I very much doubt they had ford engines, they were fitted with either the 847 or 939cc overhead cam cross flow engine from the Morris minor or wolseley 10.
old tourer
Morris 8 two seater
