Rosco663
Posted: Thu Dec 17, 2015 2:18 am Post subject: Overhauling Bishop Cam Steering |
Gidday,
Ralph was asking about how to adjust the steering on his Morris 8 inside another thread. I sent this via PM to him but thought it only fair to share with one and all
Posted: Mon Dec 21, 2015 1:59 pm Post subject: |
Thanks Rosco663! My Jowett is fitted with a Bishop Cam Box the column of which threads itself neatly between the inlet manifold and the cylinder on the off side which adds an interesting dimension to engine overhaul. I agree that most of the wear occurs on the peg, and I am surprised that they do not mention the trick, that I have used on several boxes, of simply pressing the peg out of the arm, rotating it 90 degrees and pressing back (the peg wears on 2 opposite faces only). This often returns a worn box to almost new condition with no capital outlay!
Paul |
goneps
Posted: Mon Dec 21, 2015 10:06 pm Post subject: |
Always presuming that a previous owner has not already made use of that trick, of course!
Richard |
welder
Posted: Wed Jan 06, 2016 11:09 pm Post subject: |
| goneps wrote: | Always presuming that a previous owner has not already made use of that trick, of course!
Richard |
I can't help thinking that anyone with sufficient mechanical knowledge and enthusiasm to strip and repair a steering box would have sufficient nous to get a new one made up and press it into place, should this be the case.
Ian |
Joined: 23 Nov 2007 Posts: 4330 Location: South Cheshire
Posted: Thu Jan 07, 2016 8:46 am Post subject: |
New pegs are available and only about £10, so shouldnt break the bank if required.
goneps
Posted: Thu Jan 07, 2016 9:44 pm Post subject: |
| welder wrote: | | goneps wrote: | Always presuming that a previous owner has not already made use of that trick, of course!
Richard |
Ian |
Yes, but possibly not enough nous to realise that it would need to be case hardened. Therefore Dave's suggestion of a new replacement from a reputable source for a modest sum makes a lot more sense.
Richard |
Posted: Fri Jan 08, 2016 2:08 pm Post subject: |
| Anyone like to divulge a source? |
goneps
Posted: Fri Jan 08, 2016 2:17 pm Post subject: |
Possibly Ian Harris ian@harris84.fsnet.co.uk, but certainly the various MG parts specialists who supply for the TA, TB and TC.
Richard |
