ID these wheels please
Da Tow'd
PostPosted: Fri Feb 05, 2016 12:59 am    Post subject: ID these wheels please Reply with quote
Hi Gang,
Any Idea what these wheels are and years?
bottom 2 are 6.00 16
thanks
Hank
PostPosted: Fri Feb 05, 2016 7:16 am    Post subject: Reply with quote
Middle one is a pre 67 VW
Dipster
PostPosted: Fri Feb 05, 2016 9:33 am    Post subject: Reply with quote
Not sure about the top one, but the middle one I would have said is off an older Ford (E93A?) and the last is off, I think, an old Morris of the sort that the old GPO used to used as vans post war.
What have I won?!
PostPosted: Fri Feb 05, 2016 9:40 am    Post subject: Reply with quote
The middle one looks like a wide section 16" rim, as fitted to Ford E83W Pickups (vans were usually on skinnier 18"s).
As for wheel #3, some Morrises had six-stud easi-clean type wheels iirc.
Da Tow'd
PostPosted: Fri Feb 05, 2016 5:13 pm    Post subject: Reply with quote
I as told the top wheel was from an Indian Motorcycle
middle isn't a Wide 5 rim from a VW looks close to my Thames e83w panel wheels but a little different
no idea on the last one
thanks guys
Hank
PostPosted: Fri Feb 05, 2016 5:30 pm    Post subject: Reply with quote
The middle one is definitely Ford.
Some Ford saloons had slim 16"s, the pickup had slightly widened 16"s.
PostPosted: Sun Feb 07, 2016 10:24 am    Post subject: Reply with quote
I would agree, the middle one definately looks Ford.
PostPosted: Sun Feb 07, 2016 11:32 am    Post subject: Reply with quote
The Morris 8 easy clean wheels were 17" except on some export models which were 16", the bottom one could be one of the latter?
PostPosted: Mon Feb 08, 2016 9:35 am    Post subject: Reply with quote
The red wire-spoke wheel could be Austin 7 or pre-war Morris Minor. One had the back-plate of the hub looking as in the photograph but on the other the backplate edge curves forwards and the spokes enter from what would otherwise be the reverse side.
IIRC the Austin had slotted bolt holes, so that the nuts only needed slackening and not be removed in order take the wheel off.
Both wore 19" wheels.
PostPosted: Mon Feb 08, 2016 9:52 am    Post subject: Reply with quote
The red wheel is not Austin Seven, nor do I think it's off a motorcycle. I did wonder about Morris Minor, but I don't think it's quite right; maybe early Triumph Super Seven?
PostPosted: Mon Feb 08, 2016 10:20 am    Post subject: Reply with quote
I'll get me coat
8_10 Brass Cleaner
PostPosted: Mon Feb 08, 2016 2:22 pm    Post subject: Reply with quote
top one is a just post vintage Morris minor. When they went back to side valve.
