Da Tow'd
Joined: 16 Jun 2010 Posts: 349 Location: Bella Coma British Columbia Canada
Posted: Fri Feb 05, 2016 12:59 am Post subject: ID these wheels please |
Hi Gang,
Any Idea what these wheels are and years?
bottom 2 are 6.00 16
thanks
Hank |
Posted: Fri Feb 05, 2016 7:16 am Post subject: |
| Middle one is a pre 67 VW |
Dipster
Posted: Fri Feb 05, 2016 9:33 am Post subject: |
Not sure about the top one, but the middle one I would have said is off an older Ford (E93A?) and the last is off, I think, an old Morris of the sort that the old GPO used to used as vans post war.
What have I won?! |
Da Tow'd
Posted: Fri Feb 05, 2016 5:13 pm Post subject: |
I as told the top wheel was from an Indian Motorcycle
middle isn't a Wide 5 rim from a VW looks close to my Thames e83w panel wheels but a little different
no idea on the last one
thanks guys
Hank |
Joined: 30 Apr 2013 Posts: 4202 Location: The Somerset Levels
Posted: Sun Feb 07, 2016 10:24 am Post subject: |
I would agree, the middle one definately looks Ford. _________________ Various Rootes Vehicles. |
Joined: 23 Nov 2007 Posts: 4264 Location: South Cheshire
Posted: Sun Feb 07, 2016 11:32 am Post subject: |
The Morris 8 easy clean wheels were 17" except on some export models which were 16", the bottom one could be one of the latter?
Posted: Mon Feb 08, 2016 9:35 am Post subject: |
The red wire-spoke wheel could be Austin 7 or pre-war Morris Minor. One had the back-plate of the hub looking as in the photograph but on the other the backplate edge curves forwards and the spokes enter from what would otherwise be the reverse side.
IIRC the Austin had slotted bolt holes, so that the nuts only needed slackening and not be removed in order take the wheel off.
Both wore 19" wheels. _________________ Dane- roverdriver but not a Viking. |
Joined: 31 Jul 2009 Posts: 1810 Location: Market Warsop, Nottinghamshire
Posted: Mon Feb 08, 2016 9:52 am Post subject: |
| The red wheel is not Austin Seven, nor do I think it's off a motorcycle. I did wonder about Morris Minor, but I don't think it's quite right; maybe early Triumph Super Seven? |
Posted: Mon Feb 08, 2016 10:20 am Post subject: |
| D4B wrote: | | Middle one is a pre 67 VW |
I'll get me coat |
8_10 Brass Cleaner
Posted: Mon Feb 08, 2016 2:22 pm Post subject: |
| top one is a just post vintage Morris minor. When they went back to side valve. |
