Davelowery Guest
Posted: Mon Sep 10, 2007 2:39 pm Post subject: e83w parts needed |
plz if any one has any of thes parts for sale plz msg me
100 e engiune parts i need
inlet and exhaust manifold gasket
oil filter + bolt + spring + oil fillter container
steel tube that fits into bottom of engine for the bottom radiator hose
e83w parts i neede
front and rear axle u bolts and nuts and plates
i all so have for sale
6 volt starting moter
6 volt distributor
1ooe engine stripped for rebild
complet front axel |
buzzy bee Guest
Posted: Mon Sep 10, 2007 3:41 pm Post subject: |
Hi Davelowery
I have sent you a PM
Davelowery Guest
Posted: Mon Sep 24, 2007 1:13 pm Post subject: |
there a few more parts i need hopefully have the u bolts now thanks a lot dave
still need the oilfilther houseing for a e100 engan and a coreplug
i need all the door and window seals
and the rear wheel mugguards
and a streeing weel and steering box
thanks
dave |
buzzy bee Guest
Posted: Mon Sep 24, 2007 1:53 pm Post subject: |
No probs, I need the seals myself so can't help you on that front, the rear mudgaurds are built into my pickup and don't have any others spare, and the steering wheel, I may have one, but I am not sure, if I do it will be a bit cracked, I have restored my one.
Davelowery Guest
Posted: Mon Sep 24, 2007 1:57 pm Post subject: |
i have a steering wheel but its in realy bad shape so trying to find a new on i will send u a pic so u can see if its worse than the one u have
dave |
buzzy bee Guest
Posted: Mon Sep 24, 2007 2:32 pm Post subject: |
I will try and find an article on how to restore them, it is a lengthy job, but may be an option!
Davelowery Guest
Posted: Mon Sep 24, 2007 2:39 pm Post subject: |
| thanks a lot that woud be grate |
rustyreks
Posted: Wed Aug 20, 2008 9:04 am Post subject: fordson steering wheel resto |
| Dave my steering wheel was horrific as it had been weathered outside 1/3 of the bottom base had separated and much of the bakelite material was misshaped and alot of the metal frame was visible though rusted for a cost of approx $20.00 new zealand i repaired it i first sand blasted the bakelight esp places where it had cracked and removed any loose material although the sand blaster did a pretty good job of that its important to clean the rusted frame so the epoxy putty has something to stick to i then used abit of jb weld to join up the broken section back on.then used the grinder to roughly shape the steering wheel and then used some epoxy putty i think it was called knead it it is sold in a stick it is a two part putty and you mix it up and it sets hard.After mixing it sets quite fast i shaped sections at a time as there was quite a lot of repairing to be done so far so good the hardest part was the sanding it took a good 6-7 hours to get it just right i only experimented as i couldnt find a better one but the end result was well worth the effort as it looked new i then primed and spray painted it and it didnt cost that much to do esp when it is difficult to pick up a good one.It was one of those jobs where i was going to throw the steering wheel away but thought what have i to lose and in the process ended up with a really good steering wheel can send some pics if interested in some brent |
rustyreks
Posted: Wed Aug 20, 2008 10:50 am Post subject: restoring steering wheel |
| Dave here is the site that inspired me to do my own steering wheel it was far worse than this one it was a throw away before i started it came up well http://www.secondchancegarage.com/public/480.cfm |
