New 1970s' coupe - TR7 or MGB GT?
PostPosted: Tue Mar 08, 2016 4:40 pm    Post subject: New 1970s' coupe - TR7 or MGB GT? Reply with quote
Which would you have opted for, if you'd been looking for a small mass-produced coupe in the late 1970s? TR7, with its modern and distinctive styling (hiding a Dolly engine), or a rubber-bumper MGB GT (that surely should have been pensioned off already)?
TR7:
Earlier, chrome-bumper, GT
petermeachem
PostPosted: Tue Mar 08, 2016 5:02 pm    Post subject: Reply with quote
I owned a TR7. It was the newest car I have ever owned and the only one that didn't need an MOT when I bought it.
It was horrific. No rear vision, you couldn't see what was coming up the motorway when you went down a slip road, my solution was to go very fast!
It failed it's first MOT, chassis rust, the side windows would regularly drop out of the channel that wound them up and down. This meant taking the door apart and hammering the channel back on. At 30,000 miles the timing chain slipped and destroyed the engine. The gearbox (5 speed) would not go into first on a cold morning until the oil had warmed up.
Quite easily the worse car I have ever owned. It was not even vaguely a sports car, more a wobbly jelly.
PostPosted: Tue Mar 08, 2016 5:14 pm    Post subject: Reply with quote
What a difficult choice!
The MGB was quite a handsome car in original form as was the GT but the rubber bumper cars sat far to high and just looked silly and cheap and that applied to the interior too.
The TR7 was a typical product of a real low point in car design and never appealed to me.
I would never have bought either car but I would probably have opted for the TR7 on account of better performance if I had no other choice.
PostPosted: Tue Mar 08, 2016 9:34 pm    Post subject: Reply with quote
The last time I said that the TR7 was a bad car, I was castigated for it. I don't care. I will say it again. The TR7 was a truly awful heap of junk and if they all end up on the scrap heap it wouldn't bother me. Just stand one next to a proper TR (even the TR6) and you would despair of the British motor industry. No wonder it went t,,ts up with rubbish like the TR7.
The MGB GT was, again in my forthright opinion, a darn good little car. It was nearly as good as my GT6 Mk3 but the later ones suffered from a ghastly interior, too high a ride height and those nasty bumpers. An object lesson in how to ruin a nice car. Was this the beginning of the end?
christine lowery
PostPosted: Tue Mar 08, 2016 9:36 pm    Post subject: Reply with quote
rather have a TR8
Christine Cool
emmerson
PostPosted: Tue Mar 08, 2016 9:52 pm    Post subject: Reply with quote
christine lowery wrote:
rather have a TR8
Christine Cool
Sorry Chris, but the TR8 was still just a heap of poo with a bigger engine!
Dipster
PostPosted: Tue Mar 08, 2016 11:13 pm    Post subject: Reply with quote
Could I have a Fiat 124Spider instead please?
PostPosted: Tue Mar 08, 2016 11:23 pm    Post subject: Reply with quote
I expect the MGB GT V8 would be a better bet. I understand that the V8 engine is lighter even than the 4 cylinder B unit but with a lot more grunt. You might want to lower the suspension and change the bumpers. I can't remember all the details but could be a fun car. A friend has a MGC but I feel the big six is a bit heavy in his car.
I am no expert so leave it to those who are.
PostPosted: Wed Mar 09, 2016 12:01 am    Post subject: Reply with quote
You have good taste! The Lampredi designed twin cam engine was a masterpiece!
Shame they are all LHD - but not a problem for you!
Ellis
PostPosted: Wed Mar 09, 2016 12:12 am    Post subject: Reply with quote
I expect the MGB GT V8 would be a better bet. I understand that the V8 engine is lighter even than the 4 cylinder B unit but with a lot more grunt. You might want to lower the suspension and change the bumpers. I can't remember all the details but could be a fun car. A friend has a MGC but I feel the big six is a bit heavy in his car. .
One guy in the village had a MGBGT V8 for many years, a Tahiti Blue "P" registered example.
I drove it on several occasions and was impressed by it's power and torque but not by the actual car itself. An MGBGT is very cramped inside and there is heat soak through the bulkhead and transmission tunnel.
A business friend of my late father bought a mint MGCGT in the early 1970s and kept it only for a few months because he considered the handling and roadholding to be unsafe.
I believe those faults can now be solved with modern dampers and tyres.
I never drove a Triumph TR7 nor did I want to or own one.
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
PostPosted: Wed Mar 09, 2016 1:24 am    Post subject: Reply with quote
The heat transfer to the cabin was a complaint also made against the Triumph GT6. It took me a considerable amount of time solving the problem on my car and once resolved, you realise that the heater is not really up to the job. Mad I eventually got the car as I wanted it and as a daily driver it was fine. The inside of a GT6 is even smaller than a MGBGT but not being a large person, it suited me very well and I kept the car for 38 years.
I feel the MGC was something of a damp squib. Whereas the 2 litre 6 cylinder engine in the GT6 was a heavy lump, it was nothing like as bad as the 2,912 cc engine that the MG had been lumbered with. Unfortunately, by the time the MGC was introduced (1967) Abingdon had lost control of engine design; the result was an engine around 25KG too heavy for the car. The balance was all wrong and the handling and acceleration suffered as a result. Essentially, the reason the car is nose heavy is that the engine had to be mounted forward enough to allow for the automatic transmission beloved of the important American market. Another problem with this long, tall, heavy engine was that the front cross member had to be sacrificed. As this carried the coil suspension on the 'B', a torsion bar suspension system had to be substituted. An ugly bulge in the bonnet was also required to clear the engine and larger radiator. Many changes to the standard 'B' design were needed to cope with the extra power which all added weight.
Hardly a worthy successor to the Austin Healey 3000 (in my view)
PostPosted: Wed Mar 09, 2016 10:05 am    Post subject: Reply with quote
Back in the seventies I actually made this decision!
As a long-time Triumph enthusiast I wanted to like the TR7, but a showroom examination and short test drive soon put me off. I didn't like the styling, but rather hoped it would grow on me, but driving visibility was appalling - reversing was a nightmare, and I couldn't come to terms with the windscreen disappearing into the distance with no view of the front of the car. I was running an 1850 Dolomite at the time,and the performance of the, admittedly brand new, TR7 seemed quite lethargic.
I agree, the deck-chair interior of the MGB was unappealing, but I didn't mind the rubber bumper look, and the raised ride height made it more comfortable to enter and exit.
I placed an order for the MGB GT in black with special-order oxblood leather interior ... and the very next day I was made redundant, so I never did get to own a brand new version of either car!
I have subsequently owned a couple of second-hand MGBs and a TR7 - the MGs were sold with some reluctance, the TR7 was disposed of swiftly and with relief! I'm still a Triumph man at heart, but the TR7 just doesn't do it for me.
Ashley
PostPosted: Wed Mar 09, 2016 10:31 am    Post subject: Reply with quote
We had Healeys, MGBs and a MGCGT, I liked the Bs best but they were slow and needed lots of maintenance. The MGC was hardly faster and not as fast as the Healey, just a little more civilised. Then I got an E Type, then a DB5 and, because it was too fast for the rapidly slowing traffic I bought a R-R Silver Dawn to try and contain my temper as roads became more and more congested. Then the kids appeared.... And it was a few years before we had another Rolls-Royce and what a load of crap that was. Silver Shadow.
PostPosted: Wed Mar 09, 2016 2:41 pm    Post subject: Reply with quote
I had one drive in a TR7 years ago and it fully came up to my expectations of a crappy plastic, overstyled, just wrong seventies car. I am not much in favour of the plastic bumpered MGB as well - ahhh the 70s "improvements".... Evil or Very Mad
PostPosted: Wed Mar 09, 2016 8:24 pm    Post subject: Reply with quote
The B series engine is an old design - it is as old as me! It was originally introduced in (1954) and although a properly set up engine will repay the time and trouble to get it right, there is rather less development potential than one would like for a sports car. Even with a raft of modifications, the output is unlikely to exceed 105 BHP. More power can be extracted but at greater expense than is sensible when a V8 transplant is available. A much better proposition, in my opinion, than a TR8.
With all the mods that the factory made to the MGC to handle the extra power, I wonder how the C handles with a RV8 3.5 engine? I imagine that would be a fun car. Very Happy
