Fixing my oil leaks
imperial21
PostPosted: Thu May 19, 2016 8:45 pm    Post subject: Fixing my oil leaks Reply with quote
Has anyone any tips on changing the tappet cover & timing cover on my super minx ? In particular undong and removing the cranshaft bolt and pulley ?
Thanks
PostPosted: Fri May 20, 2016 3:03 pm    Post subject: Reply with quote
Wind plumber's sealing tape around the pulley spiral so that the casing is centralised befored you tighten it up. Then remove the pulley and replace it less the tape.
