terrible wiring
petermeachem
PostPosted: Wed May 25, 2016 1:50 pm    Post subject: terrible wiring Reply with quote
This seems to afflict Austin 7's or maybe I just notice them. For instance in http://www.ebay.co.uk/itm/1936-AUSTIN-SEVEN-RUBY-Saloon-ARR-/222128347197 look at this http://aceclassiccars.com/ebay/austin51/image65.JPG
Just awful. Even Austins that don't have random extras tacked on always seem to have really messy wiring
PostPosted: Wed May 25, 2016 2:15 pm    Post subject: Reply with quote
Hi Peter,
I think quite a few owners are blind to modern detritis. Like you, I'm not and hate it.
Peter Twisted Evil
PostPosted: Wed May 25, 2016 3:42 pm    Post subject: Reply with quote
My Singer's last (and first) owner was an auto-electrician, but even then I spent many hours going through the car changing the blue crimped connectors for original style ones.
it was only on things like Radio, Spotlights and the original Lucas electronic ignition conversion but still took ages! looks so much better though (and probably more reliable as I soldered the connectors after they were crimped)
Kevin
Riley Blue
PostPosted: Wed May 25, 2016 3:51 pm    Post subject: Reply with quote
You'd hate looking under the dashboard on my Riley! A previous owner added a hazard flasher switch to enable all four indicators to flash at once. Unfortunately the switch is in a box with a tangle of wires into and out of it. It looks awful and one day I'll pluck up courage to try to fathom it out. I've no idea why he did it, the car hasn't been a 'breakdown queen' while I've been driving it.
David
1963 Riley 1.5
1965 Riley 1.5
PostPosted: Wed May 25, 2016 8:14 pm    Post subject: Reply with quote
Just do it one wire at a time, soon gets done
Kev
PostPosted: Wed May 25, 2016 9:18 pm    Post subject: Reply with quote
Note to self - never post an under-bonnet photo Smile
baconsdozen
PostPosted: Thu May 26, 2016 8:14 am    Post subject: Reply with quote
Snap.... I have a similar contraption fitted to my Mk1 transit,all the wires in and out are the same colour. One day I might have a fiddle but I dont like electrics much at the best of times.
Dipster
PostPosted: Thu May 26, 2016 8:46 am    Post subject: Reply with quote
One of my pet hates in life in general is when I have to work on something already constructed or fitted (such as an additional wiring loom) where the original installer/fabricator has left no diagrams. Worse, when no attempt at clarity (eg. same colour wires) has been made.
I have come across this many times both in cars and houses (particularly buried pipework and cables. Grrrr!). It takes a lot of time, careful thought and tracing to sort things out.
PostPosted: Thu May 26, 2016 10:04 am    Post subject: Reply with quote
My pet hate is Scotchlok connectors.
I once spent ages trying to sort out an intermittent running fault on a car, only to look at it in the dark and see one of the low-tension cables arcing to the engine. It had once had a Scotchlok connector spliced into it, the offending connector had been removed and the connection made properly, but without noticing that the part where the insulation had been pierced was exposed enough to earth to cause the problem.
goneps
PostPosted: Sat May 28, 2016 1:13 am    Post subject: Reply with quote
The first thing that strikes my eye when a bonnet is opened is the wiring, and invariably it's dreadful. Nasty thin plastic-coated wires instead of proper braided cables man enough
for a 6V system, plastic insulating tape instead of braided sleeving, those horrible crimp terminals instead of decent soldered connections, suppressor plug caps instead
of brass spades, and the whole catastrophe made worse by no attempt to arrange things tidily. Even the HT cables are usually an ugly bird's nest.
More often than not the owners are the same characters who complain bitterly that the lights are pathetic, and heap totally unjustified insults upon Joseph Lucas and 6V electrics.
Richard
petermeachem
PostPosted: Sat May 28, 2016 11:05 am    Post subject: Reply with quote
Couldn't agree more. Replacing a loom on an Austin is not exactly a huge job, braided ones are easily bought. They want an enormous amount of money for this car, they could at least have made it look decent. makes you wonder which other bits have been skimped
PostPosted: Sun May 29, 2016 11:29 am    Post subject: Reply with quote
Not just 7s here's an otherwise nice 16.
Riley Blue
PostPosted: Sun May 29, 2016 12:56 pm    Post subject: Reply with quote
That really is unforgiveable!
David
1963 Riley 1.5
1965 Riley 1.5
goneps
PostPosted: Mon May 30, 2016 12:24 am    Post subject: Reply with quote
I agree that's quite bad enough, but there was an even worse example at the Galaxy of Cars event in February. A row of three very presentable pre-war Riley saloons, all with
open bonnets, and there, on the middle one, for all the world to see, was wiring taken from a modern car complete with white plastic multiple spade connector plugs.
Had it been my car I'd have been too ashamed to open the bonnet with anyone else around. We can but hope that a special place in hell awaits the perpetrators
of such crimes.
Richard
Da Tow'd
PostPosted: Mon May 30, 2016 3:38 am    Post subject: Reply with quote
Not a classic but terrible idea on the wiring on the electric windows,doors locks and mirror in a 1995 Jeep wagon. The multi wires all bunched up in the door jam bent 90*, there must be 12 wires and I found 5 broken. No wonder why nothing worked but a paying job is a paying job.
I relate that to the nicer set up used on the Volvo wagon.
cheers
Hank
