buzzy bee Guest
Posted: Sat Sep 22, 2007 7:25 pm Post subject: Running hot |
I have just got the Ford running, first time I have heard it run and as far as I know it has been a long time since it actually ran.
Sounds fairly sweet, need a little fiddling, but it is getting very hot, after a few minutes it is boiling up, and that is on idle.
Rustyreks has mentioned about me having a water gallery blocked, but I am not sure as the water runs through ok?
Any ideas anyone?
Dave  |
buzzy bee Guest
Posted: Sat Sep 22, 2007 8:58 pm Post subject: |
The top hose looks fine and the bottom hose is fine as far as I know, it is a new hose aswell.
The rad feels fairly warm over the whole surface, but is hotter at the top than the bottom, but is this just the thermo syphon, How do you solve a blocked water gallery or rad, or how do you tell for sure?
May have another look tomorow pm, so will try anything you can come up with?
buzzy bee Guest
Posted: Sat Sep 22, 2007 9:06 pm Post subject: |
I know I put a new head gasket on, but do you think it could be a problem with this? Be worth retightening the head down, could this cause the running hot?
Posted: Sat Sep 22, 2007 9:16 pm Post subject: |
I doubt the head torque would make it run warm, although it won't harm to carefully re-torque the head after a few decent runnings (when cooled down). Just make sure your torque wrench is properly accurate (remember the aggro I had caused by a duff wrench!!)
Only other thing is timing, but if it was far out it wouldn't have started or run as well as it did last night. Did you run it again today ok?
Not sure how you'd check for a blocked water jacket, probably a long shot that one I think. I think I'd be taking a long look at the rad again if its still running super-hot. Is it worth trying that other rad that you had??
buzzy bee Guest
Posted: Sat Sep 22, 2007 9:26 pm Post subject: |
Yeah I am allways hesatant with the torque wrench, maybe that is the problem!
The timing must have been pretty good as it ran not so bad yesterday, but I thought about that today, so re timed it, and fiddled witht he mixture screws for a couple of hours, advancing and retarding too, and it got no better. This is when I came home to have a think about it!
All I can do is like you say try the other rad!
buzzy bee Guest
Posted: Sat Sep 22, 2007 9:55 pm Post subject: |
Yeah the fan belt and fan are now back on, it does create alot of draft, but it didn't seem to help that much.
I will have a look tomorow, running to lean definateley make it hot but it was set to the book, and if anything it is running rich as it is using a bit of fuel!
buzzy bee Guest
Posted: Sat Sep 22, 2007 10:10 pm Post subject: |
New old stock, but checked that today, and a god stream of gases, I was clutching at the same straws today! hehe
Posted: Sun Sep 23, 2007 8:17 am Post subject: |
I've only just seen this posting, so apologies for not answering earlier.
Buzzy, when engines are standing for a long time, rust deposits tend to settle in the block and radiator. You can try removing these with something like Radflush, but the best alternative is possibly to pop the core plugs, and clean iy that way. Make sure you have new plugs first though.
Otherwise, remove the head and check for flatness. You need a factory manual for the specs. Sidevalve heads are notorious for warping, especially if they are not removed/ replaced correctly. Check at this time that you have not fitted the head gasket wrong, and it is that which blocks a water passage.
Where is the spring posting, by the way?
UJ |
buzzy bee Guest
Posted: Sun Sep 23, 2007 11:32 am Post subject: |
The spring post will come later this evening, I am speaking to the chap today.
I have a few things now to check so I will check these on the ford and let you know how it goes!
buzzy bee Guest
Posted: Tue Sep 25, 2007 6:10 pm Post subject: |
I recon the cherry red exhaust would have been quite dark in the light, it is the same when we forge things, hence smithy's being dark!
Great pics though, thanks for putting them up, can you send me the pics when you get chance too, so I can print them off, for a milestone in the folder, when I get around to doing them?
