Care with batteries
PostPosted: Thu Oct 04, 2007 11:53 am    Post subject: Care with batteries Reply with quote
Read this on another forum, but am sure they won't object to this warning being posted here too:
All,
Last week an on-line friend had a bad accident in his garage and almost lost his eyesight. Fortunately, he is recovering and hopefully no long-term damage has been caused. My friend is going through a painful recovery and wants all to be careful so they do not suffer what he is going through.
He was working on a project car and was getting ready to prime some doors. He had plastic all laid out to protect garage and equipment from paint vapors. His garage had a fan powered by a battery and he used a battery charger to keep the battery going. The battery was situated on a shelf head high, and as he disconnected the charger there was a spark created that caused an explosion!
A critical part of the cause of this accident is that the charger was still connected with the power on. Acid batteries give off hydrogen gas as they are being charged and hydrogen can collect in an enclosed area. When the right ratio of hydrogen and air are present a spark can cause an explosion. The charger was still plugged in when my friend disconnected the cable. This caused the spark which ignited the hydrogen gas surrounding the battery.
The resulting explosion caused his face and eyes to be sprayed with battery acid. Luckily he was able to get into the shower quickly. He spent some time in the hospital and it was not known initially if he would lose sight in one eye. Luckily he seems to be recovering.
Another important component of an accident is the human tendency to lower ones guard as procedures become routine tasks. In the US, OSHA examines work place safety and history shows that over 91 % of workplace injuries and death happen during routine tasks, not first time critical procedures. Example if the charger is turned off and disconnected, a spark should not happen, and if time is given for the collected gas build up to vent, the fuel source should be dissipated.
Gasses can also be lite off from several sources including internal sparks from a non sealed electric motor fan running, a fan blade rubbing or striking metal, static electricity like plastic sheeting or a cellular phone ringing.
Be it work or home, please be careful!
Uncle Joe
PostPosted: Thu Oct 04, 2007 12:32 pm    Post subject: Reply with quote
If this accident had happened in the workplace, then presumably the employer would have been charged with offences under the Health and Safety laws.
But why is it that a lot of people tend to disregard these laws when working at home? Why cant they apply there as well?
UJ
Job-Rated
PostPosted: Fri Oct 05, 2007 10:07 am    Post subject: What's it like in prison? Reply with quote
Job-Rated
PostPosted: Fri Oct 05, 2007 10:09 am    Post subject: Reply with quote
... sorry, posted wrong...
Ignore me.
Should be easy.
