Paul fairall
Posted: Sun Mar 12, 2017 4:41 pm Post subject: 7.8mm spade connectors |
Been looking for just two 7.8mm spade connectors for an electronic power steering column without success. Did see 100 for sale but that's just stupid. They need to take 6mm cable. Any ideas? _________________ 1957 ford popular |
Posted: Sun Mar 12, 2017 6:11 pm Post subject: |
Try Electrical Wholesalers, who may advertise Ampliversal or Thomas & Betts.
Back in the 80, 90, we ran an Electrical Wholesale business and sold thousands of Ampliversal items. Bought them in boxes of 5000 and sold whatever quantity anyone wanted.
Unless you have a proper crimping tool, (the prof' tools crimp the cable and the insulation at the same time) maybe look at soldering it on. Slide off the insulation part and solder it with the terminal in a vertical position with the cable below. Tin the cable first. For 6mm sq cable the terminal size would be identified by the yellow sleeve. (Simple ID. Red Small - Blue Medium Yellow large)
Some stockist may even have the ones deigned for soldering.
We even sold nylon sleeves to slide over the terminal. |
Joined: 25 May 2011 Posts: 2727 Location: South Cheshire
Posted: Sun Mar 12, 2017 8:20 pm Post subject: |
This page has female "8mm" spade connectors at 24p each, though there's probably VAT and P&P on that, though you'll pay P&P on most things if you can't find a local supplier.
http://www.autoelectricsupplies.co.uk/product/825/category/2
ETA - no use, says "1 - 2.5mm" cable. |
Paul fairall
Posted: Tue Mar 14, 2017 10:04 pm Post subject: |
Thanks mike, I decided to visit a breakers yard for the first time in 30 years and got the blue plug I needed from a corsa eps ecu. The crimps were going to be for testing it. Someone on another forum offered me one for £6 after I'd stood on my head in the footwell of an old corsa with broken glass and soil, it cost £5. _________________ 1957 ford popular |
Kleftiwallah
Posted: Wed Mar 15, 2017 10:41 am Post subject: |
On things electrical connectors, I'm after the old 'bullet' connectors, used on motorcycles rather than cars. I only need a dozen. Any ideas out there?
Cheers, Tony.  |
alanb
Posted: Wed Mar 15, 2017 11:22 am Post subject: |
Try Paul Beck Vintage supplies, he has most things electrical. _________________ old tourer
Morris 8 two seater |
Posted: Wed Mar 15, 2017 11:28 am Post subject: |
| Paul fairall wrote: | | Thanks mike, I decided to visit a breakers yard for the first time in 30 years and got the blue plug I needed from a corsa eps ecu. The crimps were going to be for testing it. Someone on another forum offered me one for £6 after I'd stood on my head in the footwell of an old corsa with broken glass and soil, it cost £5. |
Often the best way - though if someone wanted £6 for one it sounds like a weird connector. After writing above I thought that a 7.8mm spade connector for a 6mm cable was quite strange, too, unless your 6mm includes insulation where I think the spec I mentioned does not. |
Paul fairall
Posted: Thu Mar 16, 2017 10:51 pm Post subject: |
| MikeEdwards wrote: | | Paul fairall wrote: | | Thanks mike, I decided to visit a breakers yard for the first time in 30 years and got the blue plug I needed from a corsa eps ecu. The crimps were going to be for testing it. Someone on another forum offered me one for £6 after I'd stood on my head in the footwell of an old corsa with broken glass and soil, it cost £5. |
Often the best way - though if someone wanted £6 for one it sounds like a weird connector. After writing above I thought that a 7.8mm spade connector for a 6mm cable was quite strange, too, unless your 6mm includes insulation where I think the spec I mentioned does not. | i think someone else mentioned 6mm cable whereas the cable fitted to the plug looks like 4mm multi strand. The 7.8mm is the width of the spade. _________________ 1957 ford popular |
Paul fairall
Posted: Thu Mar 16, 2017 10:56 pm Post subject: |
| Kleftiwallah wrote: | On things electrical connectors, I'm after the old 'bullet' connectors, used on motorcycles rather than cars. I only need a dozen. Any ideas out there?
Cheers, Tony.  | vehicle wiring products _________________ 1957 ford popular |
jp928
