Vintage dynamo nearly 80 years old
stevefizz
PostPosted: Tue Mar 14, 2017 8:03 pm    Post subject: Vintage dynamo nearly 80 years old Reply with quote
Hi Sorry me again
measured the voltage with the engine running on tickover and got about 7volts
measured the voltage from the dynamo with dynamo disconnected and the f and d jumpered and got 3 volts
Everything seems to work however, charges the battery and light.
Trouble with the indicators but that another story
I'v rang rounds and due to the age of it (80 years old) people are saying it will need a rebuild which is about £400.
leave alone, service it, get a new one or have it rebuilt???
Steve
PostPosted: Tue Mar 14, 2017 10:30 pm    Post subject: Reply with quote
Hi Steve,
Connecting F to D and driving the dynamo is a little indeterminate. It depends on the residual magnetism in the field pole pieces. If that is low then the dynamo may never gain enough field magnetism to get going so to speak.
You need the battery voltage on the F connection to get the dynamo started. If you just flash the battery onto the F connection then connect F and battery to the D terminal then remove the battery I think you will get a much higher output but it's a bit meaningless.
The key question is "can the dynamo generate enough current (amps) to charge the battery and light the lamps etc when connected normally?"
If the answer is no then you might need to check that the brushes are long enough to still contact the commutator under the spring pressure. If dynamo output is seriously low then you might have a shorted turn in one of the windings and that will probably require expensive specialist repair.
HTH
stevefizz
PostPosted: Tue Mar 14, 2017 11:18 pm    Post subject: Reply with quote
Thanks Pete
just had the inspection cover off and a wire fell out. it looks like it should have connected one of the field windings to the terminal. diy repair or specialist
other wise its clean and plenty of life in the brushes
PostPosted: Tue Mar 14, 2017 11:42 pm    Post subject: Reply with quote
Steve,
Are you chasing a problem the doesn't exist? This quote answers Peter's question. Since you obviously have a means of measuring voltage, does this meter have an amp function. If it does, you want to connect it in line with the D terminal and wire. The fact that you see 7 volts at the battery suggests to me that there is some sort of charging function. Getting an accurate current reading will show how well (or not) the Dynamo is performing.
EDIT
This will give you an idea where your 'found' wire may have come from.
http://www.da7c.co.uk/technical_torque_articles/threebrush_dynamo.htm
Art
stevefizz
PostPosted: Sun Mar 19, 2017 6:50 pm    Post subject: Reply with quote
The old dynamo has gone in for repair, he said ring me on Friday.
I have a spare dynamo which seemed to test okay i span it up with a drill and got 14v off the car with the f and d jumper test.
I put it on the car today every seems to work as it should a part from you need to do about 3000 rpm for the the ignition light to go out and the points to close
PostPosted: Sun Mar 19, 2017 7:17 pm    Post subject: Reply with quote
Steve,
The cut-out should be adjustable by bending the tang that holds the spring or it may have a screw adjustment. It sounds like the spring tension is too strong just now. While measuring the voltage, rev. the engine until you see 6.5-7 volts on the meter, loosen the spring tension until the points close. This should happen ar around 1500-1750 rpm. The car is 6 volt isn't it?
Art
stevefizz
PostPosted: Mon Mar 20, 2017 9:51 am    Post subject: Reply with quote
Thanks
No its 12v posative earth
PostPosted: Mon Mar 20, 2017 11:06 am    Post subject: Reply with quote
Steve,
OK, so try and get the point to close at 12.5-13 volts.
Art
stevefizz
PostPosted: Mon Mar 20, 2017 10:45 pm    Post subject: Reply with quote
no joy, only getting 0.5v on tick over across F and D.
PostPosted: Tue Mar 21, 2017 1:08 am    Post subject: Reply with quote
Why are you measuring across F & D? What do you get across D & earth?
Art
stevefizz
PostPosted: Fri Mar 24, 2017 3:34 pm    Post subject: Reply with quote
only getting 3 or 4 volt D to earth on tick over
PostPosted: Fri Mar 24, 2017 11:18 pm    Post subject: Reply with quote
Does your charge rate get varied by the main/headlight switch? Or is it a basic 3 brush Dynamo where you adjust the charge by moving the 3rd brush? Look in the window at the end of the Dynamo and see if the 3rd brush is mounted on an adjustable block? I can't remember which way you move it to increase the charge (I'm old Very Happy ) but it should be obvious if the voltage/current increases or decreases. Did you do as Peter suggested and flash the D post?. What happened to the 14 volts you had prior to installation?
It's difficult when you are not there to see the results.
HTH
Art
stevefizz
PostPosted: Sat Mar 25, 2017 1:39 pm    Post subject: Reply with quote
It is a C45 P10 part no. 224458
when i test it off the car with a battery drill seems fine easily gets 18v and i think would go higher
i dont have any lights connected yet. the position of the 3rd bush is adjustable but it did not make much difference
i have flashed it to the field terminal
PostPosted: Sat Mar 25, 2017 9:40 pm    Post subject: Reply with quote
Steve,
So you can get voltage off the car but when you install it the voltage disappears. I had a look back on the posting on this thread and it suggest that there is a problem with the car wiring. What car is it anyway? What type of regulator/cut-out is fitted. If your meter has an OHMS scale can you measure between the D wire (disconnected) and earth. I would expect something around 24 ohms or slightly higher which would represent the cut-out coil. If you could do that and report back we may get a better idea what is happening.
Art
stevefizz
PostPosted: Sun Mar 26, 2017 7:56 am    Post subject: Reply with quote
got about 30 ohms
it is a Vauxhall DX 1938
https://drive.google.com/file/d/18GtoP_0HjdP6EDOAQKs8mLzI7zEzUz85-A/view?usp=sharing
