L5Foye
Joined: 26 Sep 2014 Posts: 30 Location: Laurelvale, Portadown N. Ireland
Posted: Mon Apr 03, 2017 2:40 pm Post subject: Drilling Problem |
| I am currently restoring a vintage turnip sower. The wooden handles had rotted away and I have managed to make new ones. At each end of the handles were metal caps which had rusted away. I got new caps made from stainless steel. They are a conical shape. I need to drill a hole at the end of each cap. I cannot put the caps in a vice as it would distort them. Can anyone suggest a way of securing the caps which would allow me to drill holes? |
Posted: Mon Apr 03, 2017 3:50 pm Post subject: |
Maybe a little crude but how about putting a similar taper on a piece of doweling and just holding your end cap on the dowel whilst you grind a hole in the pointy end?
Posted: Mon Apr 03, 2017 8:10 pm Post subject: Re: Drilling Problem |
| L5Foye wrote: | | I am currently restoring a vintage turnip sower. The wooden handles had rotted away and I have managed to make new ones. At each end of the handles were metal caps which had rusted away. I got new caps made from stainless steel. They are a conical shape. I need to drill a hole at the end of each cap. I cannot put the caps in a vice as it would distort them. Can anyone suggest a way of securing the caps which would allow me to drill holes? |
Can you drill from the inside of the cone? _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
JohnDale
Posted: Tue Apr 04, 2017 10:48 am Post subject: Re: Drilling Problem |
| MVPeters wrote: | | L5Foye wrote: | | I am currently restoring a vintage turnip sower. The wooden handles had rotted away and I have managed to make new ones. At each end of the handles were metal caps which had rusted away. I got new caps made from stainless steel. They are a conical shape. I need to drill a hole at the end of each cap. I cannot put the caps in a vice as it would distort them. Can anyone suggest a way of securing the caps which would allow me to drill holes? |
Can you drill from the inside of the cone? |
Tight(ish) fit blind hole in a piece of wood & as this poster says drill from the inside - very slowly as it's stainless,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
L5Foye
Posted: Tue Apr 04, 2017 4:22 pm Post subject: |
| Thank you all for the useful hints. Much appreciated. |
