Posted: Sun Jun 04, 2017 4:21 pm Post subject: |
Don't forget to plug the hole at the end of the manifold's balance pipe section.
Might be an idea to tap it and screw a suitable brass plug inside? |
Paul fairall
Posted: Sun Jun 04, 2017 5:01 pm Post subject: |
alastairq wrote: | Don't forget to plug the hole at the end of the manifold's balance pipe section.
Might be an idea to tap it and screw a suitable brass plug inside? | it is tapped bsp I think. Will use for the vacuum wiper _________________ 1957 ford popular |
Posted: Sun Jun 04, 2017 5:08 pm Post subject: |
If it was me. I would blank them off and go for electric wipers.
Trying to balance carbs' and have a vacuum feed out doesn't sound like an ideal situation and I don't suppose I am that far out in thinking the carb/manifold was added to improve performance. |
Paul fairall
Posted: Sun Jun 04, 2017 5:38 pm Post subject: |
peterwpg wrote: | If it was me. I would blank them off and go for electric wipers.
Trying to balance carbs' and have a vacuum feed out doesn't sound like an ideal situation and I don't suppose I am that far out in thinking the carb/manifold was added to improve performance. | i admit I have been looking at an electric wiper. Thing is, the more refinements are made the more boring a car is to drive. Yesterday I took the popular out to one of our tyre depots to use a socket to remove the steering wheel and line the spokes up. I drove my work vehicle to the lock up, then drove the pop, then the work vehicle home. The pop requires my full attention to drive and the work vehicle feels so comfy, steering is precise etc etc, I've come to the conclusion modern cars are boring get you where you want to go transport that require very little effort. It's no wonder I've only enjoyed riding motorbikes the past thirty years. _________________ 1957 ford popular |
Kleftiwallah
Posted: Sun Jun 04, 2017 6:44 pm Post subject: |
Good afternoon Peter L. The spare parts booklet tells me the orinal carb' was a Solex 26FV (V for vertical positioning).
I've managed to aquire 2 of these and had them profesionally overhauled and jetted. I'll 'ave a bash at setting up what I want to do in a snap.
Cheers, Tony. |
Kleftiwallah
Posted: Sun Jun 04, 2017 7:17 pm Post subject: General arangement 'drawing' |
Hello again. I hope you can see what I'm trying to do?
Two questions, (1) the choke 'butterfly' is sprung closed. Surely they should be sprung open and only closed when attempting to start from cold?
(2) I've tried to change the linkages so they are both toward each other on the inside. Any suggestions?
Cheers, Tony. |
Paul fairall
Posted: Mon Jun 05, 2017 10:13 am Post subject: |
No photo Tony _________________ 1957 ford popular |
Joined: 23 Nov 2007 Posts: 4760 Location: Swindon, Wilts.
Posted: Mon Jun 05, 2017 11:18 am Post subject: Re: General arangement 'drawing' |
Kleftiwallah wrote: | Hello again. I hope you can see what I'm trying to do?
[img]
/IMG_0240_zpsahchhbja.jpg.html]
[/img]
Cheers, Tony. |
Kleftiwallah
Posted: Mon Jun 05, 2017 11:22 am Post subject: |
Good morning Peter, I know what has happened, due to me not being used top photobucket I uploaded the snap twice and then went back and deleted the one I had coppied/pasted. If you see what I mean.
Here it is. Two questions, (1) the choke 'butterfly' is sprung closed. Surely they should be sprung open and only closed when attempting to start from cold?
Cheers, Tony. |
Paul fairall
Posted: Mon Jun 05, 2017 1:34 pm Post subject: |
GARAGE HERMIT wrote: |
do you realise you'll have to cut a hole in your bulkhead to get the right hand carb to fit, i've just cut a hole in mine, turn's out you need 2 left carb's, no cutting then, | had a look today and a bit of panel beating to form a depression should be enough. _________________ 1957 ford popular |
GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Mon Jun 05, 2017 4:07 pm Post subject: |
Paul fairall wrote: | GARAGE HERMIT wrote: |
do you realise you'll have to cut a hole in your bulkhead to get the right hand carb to fit, i've just cut a hole in mine, turn's out you need 2 left carb's, no cutting then, | had a look today and a bit of panel beating to form a depression should be enough. |
never thought of that, might work, dont forget you'll need room for your air filter too,
i'm using "pancake" one's, _________________ 1957 - 103e - popular, |
Paul fairall
Posted: Tue Jun 06, 2017 12:17 pm Post subject: |
GARAGE HERMIT wrote: | Paul fairall wrote: | GARAGE HERMIT wrote: |
i'm using "pancake" one's, | no filters just bell mouths. _________________ 1957 ford popular |
Kleftiwallah
Posted: Tue Jun 06, 2017 1:15 pm Post subject: |
Peter, are these any good to you?
Cheers, Tony. |
GARAGE HERMIT
Posted: Wed Jun 07, 2017 8:58 pm Post subject: |
paul, here's a pic, i never cut the semi circle bit at the top, there was already a 2" hole the previous owner drilled,
and an export petrol pump will not fit with a aquplane exhaust manifold, shame,
Paul fairall
Posted: Wed Jun 07, 2017 11:13 pm Post subject: |
GARAGE HERMIT wrote: | paul, here's a pic, i never cut the semi circle bit at the top, there was already a 2" hole the previous owner drilled,
| thanks mate, get an electric pump, mine was only £21. _________________ 1957 ford popular |
