270 degree bend.
Kleftiwallah
PostPosted: Mon Jul 17, 2017 6:28 pm    Post subject: 270 degree bend. Reply with quote
An easy one for chaps of your calibre. How do I put the tightest 270 degree bend in a length of 5/15" copper tubing?
The other alternative is a 180 degree bend one way, then a 90 degree bend t'other. It's to get the fuel from the tank tap into the engine compartment.
Over to your knowledgeable selves Cheers and thanks in anticipation. Tony. Wink
It may work in practice, but not necessarily in theory!
PostPosted: Mon Jul 17, 2017 8:01 pm    Post subject: Reply with quote
5/15" seems an odd size, I'd have called it 1/3"
A 90deg bend one way is a 270deg bend the otherway.
I'm not sure what material is normally used for fuel but the stuff my garage used to replace my hydraulic pipes was bendable by hand without it crimping. If the copper tends to crimp you might need to use a plumbers bending tool or a bending spring inserted in the pipe if you can get one to fit.
PostPosted: Mon Jul 17, 2017 8:07 pm    Post subject: Reply with quote
Maybe 5/16'. 180 deg bend. That is a U shape, it is heading back the way it came.
Paul fairall
PostPosted: Mon Jul 17, 2017 11:02 pm    Post subject: Reply with quote
Refrigeration bending springs go over the pipe. Don't know if they do 5/16" springs but a small bender is available or if you need a tighter bend, use copper 5/16" bends either long or short radius.
1957 ford popular
PostPosted: Tue Jul 18, 2017 12:27 am    Post subject: Reply with quote
Any plumbers merchants will stock 8mm bending springs Smile
Kleftiwallah
PostPosted: Tue Jul 18, 2017 12:27 pm    Post subject: Reply with quote
Thanks to all those knowledgeable replies, I'll let you know the outcome.
Cheers, Tony.
Miken
PostPosted: Tue Jul 18, 2017 5:53 pm    Post subject: Reply with quote
[quote="ukdave2002"]
They will also stock 8mm copper elbows if that's any help?
jp928
PostPosted: Sun Jul 23, 2017 2:28 am    Post subject: Reply with quote
I have had success bending small bore soft tubing by a sort hand mandrel. Only works if one leg of the bend is fairly short. I found a drill that was a good fit inside the tube, and ground a dome on the back end. With a little lubrication on the end, insert dome to the point where you want the bend to start, and start loading the end away from the drill to start the bend. As you do a little bending, the drill will start to push out - just keep loading the bend area, and easing the drill out until you reach the angle you need. Done gently you should not see any kinking or flattening.
jp 26 Rover 9
