ALW Ford Popular
Posted: Tue Aug 08, 2017 8:17 pm Post subject: 103E Roof Join and Wing Joins |
Couple of detail questions please?
Where the roof meets the gutter there is clearly a 'dissimilar' metals thing going on with my Pop. Please can someone tell me what the gutter is made of and how the joint (slight groove) should be made up - looks like soft solder and some filler type stuff is present. It also appears, having cleared the corrosion, that there is an overlap join to the roof?? Hard to see how it was made.
Also, need to replace the wing joint piping. I have seen a PVC type, but it looks wrong (in my view!) where can you get the original 'rope' type and can it be over painted / sprayed?
Many thanks |
Joined: 30 Apr 2013 Posts: 4202 Location: The Somerset Levels
Posted: Wed Aug 09, 2017 9:43 pm Post subject: |
For wing piping I would go with Leathercloth, most trimmers will supply that. _________________ Various Rootes Vehicles. |
Joined: 14 Oct 2016 Posts: 2129 Location: East Yorkshire
Posted: Thu Aug 10, 2017 10:10 am Post subject: |
Are you a member of the FSOC?
If so, they will have the correct stuff..or know where to get it. |
