Just bought a Pop 103e, 1957
Goto page Previous  1, 2, 3 ... 13, 14, 15, 16, 17  Next
PostPosted: Sun Oct 01, 2017 7:38 pm    Post subject: Reply with quote
Play nicely girls.
Art
Paul fairall
PostPosted: Sun Oct 01, 2017 9:52 pm    Post subject: Reply with quote
peterwpg wrote:
There are flexible ones, dipstick.
good point Peter the one on my scudo is flexible, I would need to find one the right length or cut one to length.
1957 ford popular
Paul fairall
PostPosted: Sun Oct 01, 2017 9:54 pm    Post subject: Reply with quote
47Jag wrote:
Play nicely girls.
Art
whats that mean?
1957 ford popular
GARAGE HERMIT
PostPosted: Sun Oct 01, 2017 11:11 pm    Post subject: Reply with quote
thought the same, but the aquaplane exhaust manifold make's using the original dip stick hole a non starter, there is just not enough room, i'll post a pic tomorrow,
1957 - 103e - popular,
PostPosted: Mon Oct 02, 2017 3:36 pm    Post subject: Reply with quote
Of course, that issue doesn't arise ifa 100E engine is employed....[or at least,mine's ok?] Smile
PostPosted: Mon Oct 02, 2017 4:18 pm    Post subject: Reply with quote
Just had a measure-up of my 10hp engine, with Aquaplane exhaust manifold [but with home-made, cobbled-up, twin SU inlets]....The dipstick tube is 2 inches long.
I cannot at this moment put my hand to the actual dipstick, but I recall shortening it and re-marking, so that the finger loop sat right down on the tube end.
I measured the dipstick after the required amount of oil was put in...following a re-build. [There was lubricant in all the passages & galleries already]....thus, the top mark was evident. The lower, or 'fill' mark was simply measured from the original.
It was a fiddle to remove the dipstick, and best down with the engine quite cold. [Unless one enjoys burning one's hand on the exhaust?]
GARAGE HERMIT
PostPosted: Mon Oct 02, 2017 7:11 pm    Post subject: Reply with quote
here's a pic from underneath the car, the blanked off dipstick tube is the very short bit with the fiber washer on it, as you can see there's only a few inches between the ex manifold and the shortened dipstick tube, plus with me having a A/Q valve chest cover, that too foul's the d/s,
if you can figure out how to fit a bendy d/s, go for it, i could'nt,
Paul fairall
PostPosted: Mon Oct 02, 2017 7:50 pm    Post subject: Reply with quote
Thanks for the pic. I think a longer dipstick tube and bendy dipstick would work especially as I don't have the aquaplane valve chest and oil pipes. The dipstick on my scudo is quite long. I will try it in my pops tube and see where it comes to at the correct oil level.
1957 ford popular
GARAGE HERMIT
PostPosted: Mon Oct 02, 2017 8:01 pm    Post subject: Reply with quote
there's load's of new bendy d/s on ebay,£3 to £5, spring and flat one's, i bought a spring one to try and make it work, no luck,
Paul fairall
PostPosted: Tue Oct 03, 2017 3:00 pm    Post subject: Reply with quote
did you try a longer tube with the top where you could see it
1957 ford popular
Paul fairall
PostPosted: Tue Oct 03, 2017 3:14 pm    Post subject: Reply with quote
1957 ford popular
GARAGE HERMIT
PostPosted: Tue Oct 03, 2017 4:10 pm    Post subject: Reply with quote
d/s tube would have had too many bend's in it, then how would i screw it into the block, thought about a flexible d/s tube too, but never bothered, the sight level gauge was the easiest and simplest soloution i could think off,
Paul fairall
PostPosted: Tue Oct 03, 2017 5:10 pm    Post subject: Reply with quote
Looks like the valve chest is the main obstacle. I'm thinking I will connect a longer tube to the existing one as like you said it's not possible to screw in a tube with bends. Coming along real nice.
1957 ford popular
PostPosted: Tue Oct 03, 2017 6:29 pm    Post subject: Reply with quote
Apologies if I missed this, I'm just curious what the intended outcome after all these intriguing mods is - is it to make a "fast road" Pop using period-ish parts around the original engine? Or is it an exercise in seeing how far tuning of an E93A engine can realistically be taken with a road car?
What plans do you have regarding the rest of the running gear?
Genuinely interested!
RJ Smile
Paul fairall
PostPosted: Tue Oct 03, 2017 9:21 pm    Post subject: Reply with quote
Don't know what garage hermit, whose name remains a mystery, has in store for his mods, my own mods of twin su's on aquaplane manifold and exhaust manifold and maybe the fast road cam and 8hp head is to give it a bit more oomph up hills. Actually it's running really well at the moment.
1957 ford popular
Page 14 of 17
