Kleftiwallah
Posted: Fri Nov 10, 2017 1:14 pm Post subject: Thread cutting phenomenon |
I'm in the shed making a new brake rod from 5/16 th mild steel cutting a B.S.F. thread 5 inches long. The first two inches are spot on, but then the thread seems to form a long amplitude helix (although the threads along the whole length are acceptable).
Now, why is this happening (or has happened)?
Over to you knowledgeable people. Cheers, Tony. _________________ It may work in practice, but not necessarily in theory!
Kleftiwallah
Posted: Fri Nov 10, 2017 1:26 pm Post subject: |
Nope, not stretched. Still the original length.
Cheers, Tony. _________________ It may work in practice, but not necessarily in theory! |
Posted: Fri Nov 10, 2017 1:45 pm Post subject: |
Could it be that the rod is twisting due to the resistance to the die cutting and in so doing reduces in diameter slightly
Joined: 14 Oct 2016 Posts: 2199 Location: East Yorkshire
Posted: Fri Nov 10, 2017 3:41 pm Post subject: |
| Whilst I admit to inexperience when it comes to thread-cutting, a chum has suggested the thread form has 'stretched' because the thread itself was being cut, 'too quickly'...the die apparently can march down the rod improperly if turned too fast? |
Joined: 23 Nov 2007 Posts: 4333 Location: South Cheshire
Posted: Fri Nov 10, 2017 6:19 pm Post subject: |
| alastairq wrote: | | Whilst I admit to inexperience when it comes to thread-cutting, a chum has suggested the thread form has 'stretched' because the thread itself was being cut, 'too quickly'...the die apparently can march down the rod improperly if turned too fast? |
When I cut male threads on the lathe with a die I turn everything by hand, I'm sure someone will correct me , but I cut male threads with the die open wide, and them mak a couple of passes with it closed.
Uncle Alec
Posted: Fri Nov 10, 2017 10:03 pm Post subject: |
| Me too Dave. I convert surplus Riley RM radiator steady rods into clutch rods by doing just what you say; expand the die as far as by sending the V-pointed grub screw way in, then another run with it out and the locating grub screws tight in. |
Kenham
Posted: Sat Nov 11, 2017 9:00 am Post subject: |
| I find it easier to turn threads with the lathe , quite a satisfying job I find. All well and good if you have a lathe of course. As to the original question yes to much too soon I suspect and turning the rod instead of cutting properly. |
Kleftiwallah
Posted: Sat Nov 11, 2017 11:10 am Post subject: |
Thanks to all your knowledgeable answers,
I think 47jag has hit the nail on the head. I did have the rod projecting quite a way up from the vice jaws. I cut another length with only 1 1/2 " out of the vice at any time dieing down until I barked my knuckles only then lifting the rod higher by the same amount and the thread is spot on all the way down..
Take a sweety out of the jar 47jag!
Cheers, Tony _________________ It may work in practice, but not necessarily in theory! |
Posted: Sun Dec 24, 2017 6:16 pm Post subject: |
Forgive me for casting aspersions but you say you are making up brake rods? . That sounds like you are using some pretty crummy steel to me. I would want something a bit tougher if it was my life depending on it.  |
