Sid
Joined: 20 Sep 2017 Posts: 77 Location: From whence cometh the mighty Lagonda
Posted: Fri Sep 22, 2017 6:10 am Post subject: Polarising dynamo and voltage regulator |
I have this week bought a Lanchester LD10 that's been standing idle since the early nineties. I've cleaned the contacts in the voltage regulator and removed the corrosion from the wiring, had the dynamo out and cleaned the armature and checked the brushes and still it won't charge the battery. So I think I need to polarize the dynamo, I've seen many articles on the internet regarding this, some saying remove the wires from the dynamo, others not mentioning this. I've also seen articles where the voltage regulator has similar treatment, again some having the wires disconnected and others not. Electrics have never been my strong point so could someone run through the operation exactly how it's done please?
Thank you
Sid
Oops just realised this is in the wrong section |
Joined: 23 Nov 2007 Posts: 4289 Location: South Cheshire
Posted: Fri Sep 22, 2017 7:29 am Post subject: |
It's worth checking first if they Dynamo has any output without current applied to the feild.
All you need to do is flash the field winding and this can be done with every thing else in place.
Flashing the winding simply polarises the dynamos fixed magnets.
Sid
Posted: Fri Sep 22, 2017 8:56 pm Post subject: |
| OK thanks for that...did it and it worked a treat |
jessejazza
Posted: Thu Jan 11, 2018 1:28 am Post subject: |
| ukdave2002 wrote: | ...All you need to do is flash the field winding and this can be done with every thing else in place.
I read this post as this is also a task I have to do shortly. What do you mean by "flash"? please. |
Posted: Thu Jan 11, 2018 9:32 am Post subject: |
| jessejazza wrote: | | ukdave2002 wrote: | ...All you need to do is flash the field winding and this can be done with every thing else in place.
With the engine off, connect a wire to the "non earth" side of the battery, and with the other end of the wire touch the Field connection on the dynamo a few times (you may need to disconnect the cable thats connected to the field to physically get at the field terminal) . It will spark a little when you do this, the fixed magnets in the dynamo are now polarised.
jessejazza
Posted: Thu Jan 11, 2018 4:49 pm Post subject: |
| Thanks - i see what you mean now. |
MikeG
Joined: 16 Sep 2013 Posts: 56 Location: Cheshire/Staffordshire Border
Posted: Thu Jan 11, 2018 11:35 pm Post subject: |
Thanks for the explanation,I also need to carry out this process(I think).
To find the"Field" or non field terminal do I need to trace the connector to brush circuit ?
Mike |
Posted: Thu Jan 11, 2018 11:56 pm Post subject: |
There are normally only 2 connections on a dynamo:
1) The main Dynamo output, this will be the larger terminal, normally marked D
2) The smaller terminal will be the Field windings, this is the terminal that gets "flashed"
