A62tim
old iron
Posted: Thu May 17, 2018 5:36 pm Post subject: |
Link didn’t work for me, however if it proves to be an elusive part you could consider using the 3D printing available now. Most stuff can be replicated to good working standard. |
Posted: Fri May 18, 2018 8:42 am Post subject: |
Try Howard at Bresco, very helpful person
https://bresco.com/
Kev |
Joined: 25 May 2011 Posts: 2472 Location: South Cheshire
Posted: Fri May 18, 2018 10:23 am Post subject: |
For a reasonable quantity, that part wouldn't be too hard to make a mould for. Mould-making silicone and casting resin isn't that expensive to buy and I'm having some fun experimenting casting bits for my car.
Otherwise though Bresco is always worth a look, as Kevin said. Some of the clips on this page look as if they might do the job, depending on dimensions of course: https://bresco.com/acatalog/Moulding_Clips_-_Plastic.html |
A62tim
Posted: Sun May 20, 2018 7:04 pm Post subject: Trim Fastenings |
Thank you for the suggestions, I have managed to locate some second hand ones. |
