billybob
Posted: Thu May 24, 2018 7:44 pm Post subject: |
Bit of an update, got a new exhaust manifold, two hot spot gaskets and a manifold gasket. Fitted and gas tight.
Engine runs better and sort of ticks over but still revs rising and falling, cannot get a good setting on the air bleed screw.
After a run I can see fuel vapour leaking front and back on the carb just below the butterfly from open holes. Is this normal?
I would like to find another carburettor to replace this one as it has clearly been abused in the past. Anyone got one?
Off to Newark auto jumble next weekend for a search for one.
Jeff. |
billybob
Posted: Sun May 27, 2018 9:54 pm Post subject: |
Had a bit of luck today, found on eBay a new old stock zenith carburettor.
Should be here and fitted by next weekend.
Jeff. |
GARAGE HERMIT
Joined: 20 Mar 2017 Posts: 186 Location: stockton upon tees, cleveland,
Posted: Sun May 27, 2018 11:47 pm Post subject: |
glad you got fixed up, _________________ 1957 - 103e - popular, |
billybob
Posted: Sat Jun 02, 2018 1:22 pm Post subject: |
New Old Stock carburettor fitted. Started first pull and runs fine, ticks over nicely.
Out for a drive tomorrow weather permitting 🤞
Thanks for your help in sorting these problems out. 👍
Jeff. |
