Temp sender
trampintransit
PostPosted: Mon Nov 19, 2018 4:03 pm    Post subject: Temp sender Reply with quote
Armstrong Siddeley Star Sapphire. Temp sender appears..as are most things on this car...to be unique ,or at least rare to type.
stamped Smiths, marked 3500/0 then another obscured digit which may also be a 0 or a 9 ?
60mm long....15mm across the threads..with a tapered seat.
Near open circuit cold...about 40ohms in boiling water ( does that sound right? )
Any idea who might have stock ? [/img][img]
[/img]
'60 Armstrong Siddeley Star Sapphire
'80 Reliant Scimitar
'47 Jaguar MKIV --- in bits!!!!
petelang
PostPosted: Mon Nov 19, 2018 5:23 pm    Post subject: Reply with quote
Have you tried ASOC stores? These sort of parts they usually hold.
Alternatively, try Speedograph Richfield in Nottingham.
They do instrument repairs so should be able to tell you the technical info.
winchman
PostPosted: Tue May 28, 2019 4:29 pm    Post subject: Reply with quote
I had a similar issue.
Find one that fits in the hole, run the engine up to normal and see what it reads. If you are lucky you can add resistors to get the gauge to sit in the middle.
We initially used a decade box to switch in and out various values until we found the correct value.
https://www.ebay.co.uk/itm/Resistance-Box-Precision-Variable-Decade-Resistor-Resistance-Box-0-9999-ohm/372614399857?hash=item56c18c8771:g:ImsAAOSwwcFcd7gI
In modern vehicles I have fitted these to trigger an alarm if too warm
https://www.ebay.co.uk/itm/DC-12V-Digital-Temperature-Controller-Thermostast-Temp-Alarm-w-NTC-F8G0/113754972503?hash=item1a7c532157&enc=AQADAAADAFjVrDbVsZ8oH%2F8PNHtt9VX4%2Fw7FZcmMuqsX8uaFEduVFy68kAw%2BL6TPMZWd%2Bcuyhmsfo%2BidwAgWmyYrnnH13jYKu%2FUJFdCdBd0Rs64cu9UU4p%2BRqbn5NJVtOaMYTPiH8ulyWqy55aGyM3bomd0lZ038iFVdkaL27s0xjYkG%2B4ykIpATlomGDrtwpaMn5R0apOBgNelv7z9dnzx3Nvrw2CFEaJnfSQVcL7RCJVL2gFKK3l1wWntk6a4a6rQICrv0y01M1q1HVTejkvNo4vvbFXMMEGMDepWuCZaQooNHvXvysqBwSNuxhFduN5M2gxIJgHxHYmAE4E28MiOrrrmEhTOHUxoWlt8FGRKZy1h5UEDA4WtvZnJVZ9LkGdwo%2BNWZXft0Vyap5jYOcLa1UtyPEo6%2B4e6IqUQjke34tj3vl2xBZWGyMw44V75MkCTBDy2zHQuJry98fVBQ3giExw391QojWlXu6qrizEutQGQpMyWjaSJS%2B7mlo3dEzSN8KJ1qA9gxlTKNYfxP%2F1sQ%2FzTldJeQoPSSbktygQnhweUigXyU4ep9ZR0nUBsmWeNvfB9QDyuMJaqfEWg8g04fikkgLKGX2oBS6CazBfDbZpNAerVP90CtkYiRZBEfNkXNH7V7ctT9FhMMn1AEEADpJVKjQDtsQ1cGpmDAx9foV%2Bk70RMFHu67ZaOWgqt6%2F7SGBrTgEo4gr80RUt%2BKJkaDkXEYzECV8vyjR7JwlmLC81Mvm%2BcJe6UkLxZij7T2kpjP%2FK1JSnAP5STDAjOy00yvRRC9RCGVG7dNOsQS4yaQ4vi6X0g0lWHWlj33622x%2F4lwK%2FxdV93J%2BMmKF2Iwy3GAAkGYSB5AQ0gueIU4R%2BaS%2FVl1myFdwAKyPLm%2BExJnUrWWvXVm0tJBNllCxE%2BalbhiPKKTcorj4KolqTInkAm83wCXMABv1ygkBVIgQWrR0YXm8zQjvmhEPbV8GjFSdoPpUM0k4hh44j%2FvevsFmVDHSJRo63umFehF5qSmt82P52c9RF%2FUow%3D%3D&checksum=1137549725037dc57a3db13e46cdbe1fe45e80fdaabc
It will come in handy even if you never use it.
