robo0121
Joined: 11 Nov 2013 Posts: 49 Location: Birmingham West Midlands
Posted: Fri Jan 11, 2019 3:49 pm Post subject: landcrab wiper motor |
Hi all.i have a 68 austin 1800 and am looking for a replacement wiper motor .nos or a good 2nd hand one..numbers on the top of the casing are
6 WA 54071307E
12V 2 6875525E
Failing that theres nothing around.does anybody on here know where i can get it refurbished
many thanks in advance..Rob...
i live in birmingham uk |
Posted: Fri Jan 11, 2019 8:08 pm Post subject: |
Robo
I think that's a DR3A motor, fitted to a wide variety of cars. The major difference is the wiper arc & that can often be fixed by swapping the drive gear.
There's very little difference between the various models - my Mini had a 2-speed Jag wiper motor - a straight swap.
Realistically they are not hard to overhaul, the usual problem is hardened grease & a good cleaning will fix most problems.
Tip: mark the wheelboxes & wire-wound rack before dis-assembly. They only wear on one side, so inverting the rack will give you a new one! _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Mon Jan 14, 2019 6:44 pm Post subject: |
I use MAES in Rotherham for overhauls. a bit of a step from Brum, but they have lots of experience and they do a good job. Talk to Sam there! |
Joined: 23 Nov 2007 Posts: 4106 Location: South Cheshire
Posted: Mon Jan 14, 2019 9:28 pm Post subject: |
The DR3A was fitted to loads of vehicles, as MVpeters commented, you just require the correct wheel in order that the right angle sweep is obtained. In terms of fixing the DR3A, a new set of brushes and cleaning out 50 or 60 year old grease that's gone hard will cure most problems.
