Water in the sump!
traction39
PostPosted: Fri Jan 04, 2019 1:27 pm    Post subject: Water in the sump! Reply with quote
Having spent the last 10 years+ rebuilding my 1932 Riley 9 Special I have finally managed to get it to a point where the engine is running.
However, there must be a hairline crack in the block as I have a small amount of water in the sump. This will necessitate a complete dismantling and check. Crying or Very sad
In the meantime, is there anything I can add to the water to temporarily "heal" the crack and allow me to continue checking everything.
Any recommendations? Casting repair companies etc..?
This car had been in storage since 1963 so it would be nice to get it back on the road before the next century!!
Alistair
Alistair
Riley 9 Special 1932
PostPosted: Fri Jan 04, 2019 1:31 pm    Post subject: Reply with quote
I've used K-Seal to good effect in the past, having been recommended it by one or two people whose judgement I trust.
Rick (OCC Admin)
PostPosted: Sat Jan 05, 2019 1:02 am    Post subject: Reply with quote
Alistair,
What is it that makes you suspect the block is cracked? It could just be a head gasket or some other place where the oil and water are in close proximity. Is it possible to rig up a pressure tester for the rad? I made one for my 47 Jaguar using a spare cap and a rubber valve stem and ‘pumped up’ with a bicycle pump. It worked a treat revealing my leak.
Art
consul 57
PostPosted: Mon Jan 07, 2019 5:15 pm    Post subject: Reply with quote
k seal is very good, sealed my sons leaking motocross bikes radiators whilst running it!
RogerB
PostPosted: Tue Jan 08, 2019 10:09 pm    Post subject: Reply with quote
'BARS' Leak fluid is very good';I use to use it in my Holbay 1000cc F3 engine!
RogerB
PostPosted: Tue Jan 08, 2019 10:44 pm    Post subject: Reply with quote
I can't claim any recent experience but many years ago I formed the opinion that pour-in products may or not stop leaks but they are quite effective at blocking the passages in radiators.
falconriley
PostPosted: Thu Jan 17, 2019 6:23 am    Post subject: Reply with quote
It could easily be a cracked head or leaking head gasket, especially if the head has been faced too many times. I have been told that cracked heads are not uncommon on Nines but I have yet to see one.
I would remove the sump and rocker carriers and pressurise the cooling system to try to identify the problem. The engine in my Nine had to have a lag tappet bore sleeved as it had corroded through to the water jacket but I haven't heard it a common occurrence.
A friend used Irontite Ceramic on his Fiat 519 quite successfully.
Matthew
traction39
PostPosted: Sat Jan 19, 2019 1:58 pm    Post subject: Reply with quote
Update: Added a sealing fluid and all seems OK now. Unable to test it on the road as it has no tax...not even Historic status! Paperwork done to change the status and looking forward to the crash gearbox Laughing
Need to keep an eye on it to see if it is cured.
Alistair
Churchill Johnson
PostPosted: Sat Jan 19, 2019 10:17 pm    Post subject: Reply with quote
I have used a product called steel seal not cheap at about £30+a bottle but it was used on a kubota diesel which was leaking oil into the coolant suspect crack in block, this engine i treated 2yrs ago and being in a commercial mower is used almost every weekend during the cricket season and so far it's done the joib,it can be used with anti-freeze it will not block the rad tube's..
