Cast Iron Welding
PostPosted: Thu Apr 11, 2019 10:16 am    Post subject: Cast Iron Welding Reply with quote
Does anyone have any experience of using companies to weld/stitch cast iron cracks and fractures?
I have googled and there are a few companies out there who offer services for vintage vehicles.
PostPosted: Thu Apr 11, 2019 12:15 pm    Post subject: Reply with quote
Big Dodge's engine block required a lot of stitching, including down behind a liner in one cylinder which took some doing. Lockstitch did it all, although a few places do it I believe.
http://www.oldclassiccar.co.uk/dodge_rebuild/part11_engine.htm
Twelve years ago now - yikes!
The head also received a lot of work to make it good again, including the replacement of a large section where it had frost damage. After a few years it did begin to seep from the stitches, however by that time I'd tracked down a replacement head so had it skimmed, and fitted it myself, the original is now back on the shelf "just in case".
PostPosted: Thu Apr 11, 2019 1:03 pm    Post subject: Reply with quote
My first quote is back, to do the 2" break on the neck the the housing, £354 ex VAT and postage!?!
I expect it to be expensive but not that expensive!
PostPosted: Thu Apr 11, 2019 4:24 pm    Post subject: Reply with quote
A competent welder should be able to weld it. You could bring it to my friend who has been doing repairs to cast iron blocks before and would do it much cheaper. Snag is he is in the south of the Netherlands.
PostPosted: Fri Apr 12, 2019 3:55 pm    Post subject: Reply with quote
If it’s a non stressed component like a water manifold I would have thought brazing would be adequate.
Art
PostPosted: Fri Apr 12, 2019 4:26 pm    Post subject: Reply with quote
Its the part of the thermostat housing that the top radiator pipe fits on, it has to be watertite.
PostPosted: Fri Apr 12, 2019 7:52 pm    Post subject: Reply with quote
Rooted,
Brazing is just using brass filler rod and is easily hand finished with a file and it’s cheap. That’s the way I would go.
Art
PostPosted: Sat Apr 13, 2019 9:12 am    Post subject: Reply with quote
I am just concerned that when the pipe is re-fitted and the jubilee clip is tightened it could crack the brazing. The fracture is quite large so would require a section of metal brazed or welded back in place.
PostPosted: Sat Apr 13, 2019 9:27 am    Post subject: Reply with quote
Big Dodge's cylinder head had an in-period brazed repair along its length, which had given way over the years, so I'd be inclined to go with something more long-lasting IMO. Is there no possibility of finding a replacement housing?
PostPosted: Sat Apr 13, 2019 10:18 am    Post subject: Reply with quote
I have adverts out in the UK looking for the housing, I have also gone out to my friends in NZ and OZ.
The housing is peculiar in only being used on this engine and only between 1948-51.
I have considered drawing up a housing to suit using a more modern thermostat and then having it machined out of aluminium.
PostPosted: Sat Apr 13, 2019 11:14 am    Post subject: Reply with quote
.......or, what about 3D printing?
PostPosted: Tue Apr 16, 2019 4:55 pm    Post subject: Reply with quote
We have a 3D printer at work.....
