Goto page Previous  1, 2, 3 ... 31, 32, 33 ... 120, 121, 122  Next
BigJohn
PostPosted: Sat Apr 06, 2019 4:03 pm    Post subject: Reply with quote
Road testing after setting the timing on the Escort this morning I snapped the throttle cable. Fortunately I was not not far from home, so I popped into a friends garage to borrow a screw driver and limped home on a wound up tickover. The first new cable I found in my spares was a pre 1969 so wouldn't fit, the second was the right one (ish) it had a Metric socket and I had an Imperial ball, so had to be drilled a fraction, but all good now. Happy Days!
1974 Mk1 Escort.
PostPosted: Sat Apr 06, 2019 4:50 pm    Post subject: Reply with quote
My P38 has resumed it's annoying practise of discharging the battery. It has gone from fully charged down to 2 volts in a few days. I guess it is due to the fancy relay under the passenger seat that keeps trying to even up the EAS. Now that I have the settings installed I need to swap it for a normal one.
emmerson
PostPosted: Sat Apr 06, 2019 5:35 pm    Post subject: Reply with quote
My LSE used to do that, but it took a week to fail to start. Failing to find the source, I fitted a product called Dis-Car-Nect which worked well. It was also a theft deterrent.
PostPosted: Sat Apr 06, 2019 5:47 pm    Post subject: Reply with quote
Thanks Emerson I will have to consider that devise. Good call.
PostPosted: Sat Apr 06, 2019 6:56 pm    Post subject: Reply with quote
Today I cleaned up little Dodge and took it for a number of local hops, roof down as befitted the great weather.
PostPosted: Sat Apr 06, 2019 8:54 pm    Post subject: Reply with quote
Checked the float needles of the Jensen because it did loose fuel. Cleaned, did not think it would help but it has solved the leak issue. Took the car for a fast drive Very Happy
The Chamois is on the car lift now, I have to check the front brakes as it has a tendency to turn left. Hopefully just an adjustment, but maybe a leaking wheel cylinder. I hate the drum brakes of the Imp, they always need attention. The car needs another bi-yearly inspection soon so I will do a thorough inspection.
PostPosted: Sun Apr 07, 2019 1:05 pm    Post subject: Reply with quote
Nothing done on the Commer today, we are still trying to find parts to finish her. We cleared some of the shed out and by use of our large engine crane we got the ERF's Gardner 5LW block inside under cover. Thats a start on the restoration.
PostPosted: Sun Apr 07, 2019 6:25 pm    Post subject: Reply with quote
I took the Firenza out for a short drive - maybe six or seven miles - as it was a nice afternoon. It hasn't been out for a while, and I wanted to check it over. It all seems fine.
PostPosted: Mon Apr 08, 2019 5:31 pm    Post subject: Reply with quote
We want to get the 47 Hillman ready for a run at the start of May. I've spent some time today looking for new plugs, points etc.
PostPosted: Fri Apr 12, 2019 1:51 pm    Post subject: Reply with quote
Not a good day yesterday with the car, had a day off work and weather was lovely. Started the Hillman and drove her out the garage and sorted a problem with the started pull sticking.
Problem was though whilst reversing her back into the garage the rear passenger wing got caught on a cardboard box, it managed to get wedged and in the process take the bottom 4 inches of badly filled wing surface off (filled during the 70's I might add). I was surprised there was that much filler there and the metal underneath looks pretty poor.
Maybe just to get by its some more filler skimmed over and a local bit of spraying. Ideally she should have a full rub down and respray but I dont have the time, money or inclination.
Not happy.
PostPosted: Sat Apr 13, 2019 5:45 pm    Post subject: Reply with quote
Not working to my car, but to the garage. My garage door opens up immediately on the pavement and street. This is not a happy situation when I have to tune the engine: need to open or half open the garage door and have the engine running with the exhaust open to the pavement (and passers by). It also makes a lot of noise which understandably is not appreciated much.
In the past when I ran a small workshop with a friend in my garage we had a chimney installed with an electric motor underneath, with a long hose to stick onto the exhaust to suck away the exhaust gases. When the company moved to a bigger garage the motor and hoses went with it. There still was the chimney though so I bought a cheap secondhand motor and hose, plus a new flexible aluminium hose for the chimney and installed it all today. Had to make a split in the hose because the Jensen has two exhausts.
It works great, very happy with it.
PostPosted: Mon Apr 15, 2019 9:29 am    Post subject: Reply with quote
The last few times I've needed to start the SS I had to use the handle so today I bought it a new type 242 battery. Looking up my receipts I bought the last one in 2005 and it cost £70. It's replacement has just cost me £160. Sad
Can't complain about the life span though. The previous one to the current one was bought in 1993.
PostPosted: Mon Apr 15, 2019 10:01 am    Post subject: Reply with quote
I ran the Sportshatch yesterday, to try to get it a bit used to starting, but I still needed a quick spray of Easy-Start in the front filter before it would go. Then I washed the lower half as I'm in the process of organising the stripes to go along the side - I'm not happy with the paint, but I think the stripes will just finish the car off, and they're not too expensive to get again when the paint is sorted. If I keep putting things off while I decide what to do with the paint, I'll never get anything done.
I've also removed one of the indicator / sidelight units to put some tape around the wires - I've never been happy with the three individual wires being visible, even though it's original. Just looks messy to me.
The other reason for running it is that I'm trying to get the fuel down to the minimum so I can remove the tank and stick some sealant in it. It's got a leak right up at the top somewhere - maybe in the seam between top and bottom pressings - so I can't fill it up without it dripping onto the rear silencer.
PostPosted: Fri Apr 19, 2019 5:20 pm    Post subject: Reply with quote
Thought I had lost a piston from my stripped down Gardner 5LW engine, searched through a lot of boxes and shelves this morning and luckily found it!
PostPosted: Sat Apr 20, 2019 1:37 pm    Post subject: Reply with quote
Currently trying to modify a battery retaining frame to allow me to secure the Type 242 I've just bought.
Page 32 of 122
