poorcol1964
Posted: Sat Jul 20, 2019 9:37 am Post subject: e493a , compatibility 103e etc. |
| i have an e493a prefect , does any one know if items such as brake assemblies are compatible with the 103e pop ? |
Joined: 14 Oct 2016 Posts: 2119 Location: East Yorkshire
Posted: Sat Jul 20, 2019 12:53 pm Post subject: |
Brake assemblies, axle cables, trees, etc all the same....As the Prefect is a bit longer than a pop, in chassis length...as far as I know, the only differences will be in the length of the rods from the brake pedal assembly, to front or back axle. If missing, these are simple steel rods, threaded to take clevises each end.
Aside from pre-war models [Ys, Cs, etc], and the larger [E83W] commercials, the brake parts were common across all 'upright' post-war Fords.
Are you a member of the Ford Sidevalve Owner's Club? [FSOC]
If not, worth joining for access to a huge parts inventory...membership means, no postage charges. _________________ Dellow Mk2, 1951 built, reg 1952.
Joined: 30 Apr 2013 Posts: 4173 Location: The Somerset Levels
Posted: Sat Jul 20, 2019 1:07 pm Post subject: |
Ford kept things very simple throughout the range. So many inter-changeable parts. _________________ Various Rootes Vehicles. |
poorcol1964
Posted: Sat Jul 20, 2019 8:09 pm Post subject: |
yes I'm a member FSOC, but like most suppliers they only do an exchange for brake shoes which can be a pain .
I'm looking for spare shoes for the prefect so when they need changing i can do them there and then , not wait 10 days after having to send my old ones away ! |
Posted: Sat Jul 20, 2019 8:26 pm Post subject: |
Have you contacted the Spares Sec, FSOC? The issue may be easy to overcome.
Plus....you can always 'do them yourself?'
In other words, buy the linings[8 of them are needed]....already drilled & countersunk if you're lucky!
Ten, either purchase one of those [american] brake lining riveting tools..or make a die yourself, and rivet new linings onto your existing shoes?
[This is common practice amongst Ford Model A owners] _________________ Dellow Mk2, 1951 built, reg 1952.
