Car lift/tilt ramp.
Colin916
PostPosted: Sun Nov 10, 2019 8:24 pm    Post subject: Car lift/tilt ramp. Reply with quote
Just wondering if anyone has used one of those small ramps available now for about £400. They only lift 585mm but tilt for and aft.
They look tempting, but I'd like to hear from anyone who's used one.
Thanks
Colin.
PostPosted: Sun Nov 10, 2019 10:43 pm    Post subject: Reply with quote
Have you got a link, perchance?
Colin916
PostPosted: Mon Nov 11, 2019 10:32 am    Post subject: Reply with quote
Google. Mini tilting car lift CL03
Looks handy, but also has the potential to be crap! I can't decide
PostPosted: Mon Nov 11, 2019 11:26 am    Post subject: Reply with quote
https://www.youtube.com/watch?v=Sz-g75cCIOI
I notice the guy in the video doesn't get underneath the car at any point. Can't say I blame him for that, I certainly wouldn't want to go underneath a car supported on one of these - it doesn't look either strong or safe IMO. I reckon if it was really man enough for the job it would be impractically heavy, indeed it may be impractically heavy as it is - again, we don't see it being moved.
I don't like the idea of powering it with a drill either, I've never seen any drill-powered device that didn't fall into the category of nasty but not necessarily cheap.
D4B
PostPosted: Mon Nov 11, 2019 5:47 pm    Post subject: Reply with quote
Looks dangerous to me. What's wrong with a good old trolley jack and axle stands that you can actually place under proper jacking points, or chassis or wishbones etc....
Imagine a bigger car on this. I certainily wouldn't climb under a car on that!
Shocked
Kenham
PostPosted: Mon Nov 11, 2019 6:45 pm    Post subject: Reply with quote
Looks about strong enough to lift a lawnmower. I realise a lot of people would not have the space but I bought a 3ton four post Bradbury lift for £200, only a couple of years ago. The only thing I can't work out was why I waited until I was 60 before getting one, just makes life so much easier.
PostPosted: Mon Nov 11, 2019 7:06 pm    Post subject: Reply with quote
I don't like the idea of being able to tip it back and forth while up in the air, being underneath while that happened wouldn't be much fun.
PostPosted: Mon Nov 11, 2019 7:32 pm    Post subject: Reply with quote
There's a chap on another forum that uses a similar kind of thing, but by the sound of it (I haven't watched the video) it's much more sturdy, and also much more expensive. I'm not sure if his tilts or not, I've never seen photos of it tilted.
PostPosted: Mon Nov 11, 2019 10:09 pm    Post subject: Reply with quote
I remember at school in the 6th form we designed and made a 150mm high 150mm wide simple balsa wood structure that weighed 15g, it had to support a 50kg + load; to demonstrate its strength we had a a wooden drawing board on top of the the balsa wood structure with a school lad nervously standing on top of the drawing board, he was nervous because the whole lot was on a table on the stage at a school assembly!
The exercise was to promote the schools engineering academia, but it also demonstrated how something properly designed doesn't have to look robust to be robust.
Kenham
PostPosted: Mon Nov 11, 2019 11:03 pm    Post subject: Reply with quote
I quite agree but personally I think it helps if I am laying underneath it
PostPosted: Tue Nov 12, 2019 11:22 am    Post subject: Reply with quote
I don't think I could use one of these lifts. My garage roof trusses are too low for inside use and my drive is on too much of a slope (in two directions) to safely use it outside.
PostPosted: Tue Nov 12, 2019 1:51 pm    Post subject: Reply with quote
A good chum purchased one of these a little while ago[I drove him down with a trailer to fetch it]......
Simple enough to use, heavy [not 'arf!]...but has mobility..[just needs a bit of thought if one is 'old'..].....
He currently has a series 1 LR on it.....needs to watch his workshop roof trusses [should I say, 'shed?']
Doesn't know why on earth he didn't get one 20 years ago???
Finds it useful for wheel & axle work, as he can sit on a chair, and the hub is at the right height.
A bit pricier, but good quality, good service, and will stow away fairly flat [under a vehicle?]...out of the way, if stuffed for space?
https://www.ebay.co.uk/itm/CAR-LIFT-MOBILE-SCISSOR-LIFT-GREAT-FOR-HOME-WORK-USE-/333384917756?_trksid=p2385738.m4383.l4275.c10
PostPosted: Tue Nov 12, 2019 2:05 pm    Post subject: Reply with quote
Working on that Land Rover, say on a wheel suspension, I would feel very scary. Seems any time you use a big wrench or something the car can topple.
Not for me these mini lifters (I have a proper old 3 ton drive on car lift in my garage)
Colin916
PostPosted: Tue Nov 12, 2019 2:43 pm    Post subject: Reply with quote
Maybe make a couple of steel props for it to wedge under once she's up.
BigJohn
PostPosted: Tue Nov 12, 2019 5:13 pm    Post subject: Reply with quote
I have a height problem, so a 4 poster is out of the question, but every time I'm in Costco I gravitate to the aisle with these on, maybe next year...
https://www.costco.co.uk/Tyres-Automotive/Automotive/Trolley-Jacks-Axle-Stands/QuickJack-Portable-Automatic-Car-Lift-System-Jack-2268kg-Capacity-Model-BL-5000SLX/p/1268102
1974 Mk1 Escort.
