Goto page Previous  1, 2, 3 ... 49, 50, 51 ... 119, 120, 121  Next
alanb
PostPosted: Sat Jan 25, 2020 8:05 pm    Post subject: Reply with quote
If they were mine I think I might try a coat of high temperature clear lacquer, they look to good to paint but would deteriorate to quickly left unprotected.
old tourer
Morris 8 two seater
PostPosted: Sat Jan 25, 2020 10:04 pm    Post subject: Reply with quote
Hello Alan.
I didn't know you could get a "high temperature" lacquer. I shall have to look out for some.
As a temporary fix I have just applied some polish.
alanb
PostPosted: Sun Jan 26, 2020 3:04 pm    Post subject: Reply with quote
May work on your brake drums
Dinitrol Corroheat 4010 Clear High Temperature Wax Laquer (500ml)
£19.00
Maintain an immaculate engine bay with Dinitrol Corroheat 4010 – Clear Wax Treatment, a heat resistant, corrosion prevention giving a hard, transparent, protective, dry film.
In stock
old tourer
Morris 8 two seater
alanb
PostPosted: Sun Jan 26, 2020 3:09 pm    Post subject: Reply with quote
Here is another that may do the job
E-Tech XHT extreme high temperature lacquer.
Developed using the latest advances in paint technology - XHT is designed for use on surfaces that are exposed to extremely high temperatures.
old tourer
Morris 8 two seater
PostPosted: Sun Jan 26, 2020 3:34 pm    Post subject: Reply with quote
Thanks Alan. I have ordered some XHT lacquer.
alanb
PostPosted: Sun Jan 26, 2020 4:20 pm    Post subject: Reply with quote
I look forward to seeing the results
old tourer
Morris 8 two seater
PostPosted: Sun Jan 26, 2020 6:35 pm    Post subject: Reply with quote
I hope there will be no change! Wink
PostPosted: Sun Jan 26, 2020 6:45 pm    Post subject: Reply with quote
We moved the Hillman 80 from our garage down to the big shed this morning, moved her into the space vacated by the Karrier. We started moving some shelving and thats when it went wrong! A wooden shelf slipped and almost took the tips off two of my fathers fingers!
I took him straight to A&E where after only a short wait he had to have stitches.
Future rule in the shed, any moving of boxes or re-arranging of shelving etc will require gloves! I think we may even put up a notice on the wall as we seem to keep forgetting simple things like this.
PostPosted: Sun Jan 26, 2020 6:58 pm    Post subject: Reply with quote
Ouch, could have been very nasty.
It reminds me of once I was underneath a running engine, to see if I'd cured a leak from the rear of the sump. I had a rag with me, and was wiping a few older oil marks from around the sump, when the rag was sucked into the bellhousing by the spinning flywheel that was visible through a small access hole. Naturally my hand went with it momentarily, enough to lob the corner of my RH little finger off. That stung somewhat, fortunately it grew back ok but it was a stark reminder to be careful. It took a while to fish out the remains of the rag too, which had gone around with the flywheel until it locked the engine. The rag hangs in the garage as a stark reminder ...
PostPosted: Sun Jan 26, 2020 7:02 pm    Post subject: Reply with quote
I share your frustration at what seems to be an inevitable part of getting older, ie; forgetting to take precautions that in years gone by you would take as a matter of course.
The other day I thought I would bend back a bracket on the TC chassis. I knew there was a possibility that it would snap off but for some reason I just bent it back without a thought. Of course it snapped off... and I whacked my finger. It could have been worse but fortunately I was just in pain for a few hours.
I welded the bracket and took all the necessary precautions. It's when you don't know you have a memory problem that you have a problem,,,if you know what I mean.
PostPosted: Sun Jan 26, 2020 7:03 pm    Post subject: Reply with quote
My automotively-created injuries have only been exceeded recently by washing up injuries..
When asked if I'd been i hospital for anything recently, I had to reply, only to get bits sewn up, or stitched back on....not been ill at all...
Anyone noticed how, as we get older, how easily we leave huge gobs of blood all over the workbench, engine bay,,,,and paint doesn't stick to dried blood?
PostPosted: Sun Jan 26, 2020 7:41 pm    Post subject: Reply with quote
I put the choke mechanism back on the car today. I've had this in pieces to see if it was causing the problem with the car being difficult to start after it has stood for a few weeks. I've swapped the disc inside the choke for one that has larger holes than the original, and cleaned it all up of course. I re-fitted it earlier in the week but it leaked petrol as it was difficult to get onto the screw heads, but I've done it again today and it seems OK.
I tried to start the car, and it started reasonably easily, a big improvement as it hasn't run for about 3-4 weeks. However, when I first re-fitted the choke I tried to start it for a while, so that might have influenced things. I now have to leave it a few more weeks and try it again. I've also fitted a replacement choke cable as the original one was very stiff, so it's easier to make small adjustments to how much choke to apply, even though the design of the choke means there are only really three settings.
As someone on here mentioned it, I did remove the engine earth strap to check that I'd removed some paint to help conductivity, and I had. I gave it a bit of a clean though.
While the trim panel was out, I also cleaned some contacts that were stopping the lighter socket and illumination from working. I must get the sat-nav bracket made now I'll be able to plug it in.
PostPosted: Mon Jan 27, 2020 11:52 am    Post subject: Reply with quote
My father is 73 now and is so accident prone, first thing my wife usually asks when we get back from the yard is if my Dad's ok.
It is the 3rd time we have taken him to A&E from injuring himself with the vehicles. We both need to be more careful.
PostPosted: Mon Jan 27, 2020 12:08 pm    Post subject: Reply with quote
Hope all is well with your father.
Regarding "moving some shelving" - it seems half of all time spend in the garage is by cleaning up the work place, finding new spaces, making new shelves and moving things around.
PostPosted: Mon Jan 27, 2020 2:07 pm    Post subject: Reply with quote
We were actually looking at raising the level of our large racking to the next rung position, in doing so our Commer lorry could be moved back a further 4 ft in the shed creating more room for work in front.
We had done the hard work in completely clearing boxes from the shelf.
Fathers OK, I have text him this morning. If it were left to him he would have just wrapped a dirty old piece of tissue round his fingers and tried to get on with it!
Page 50 of 121
