Posted: Thu Sep 24, 2020 5:21 pm Post subject: |
I have tried to get the coil to pass a current by doing as you suggest but the bulb will not light.
I have tested across the points but nothing is getting through. I get the feeling that the coil is duff.
If the coil has burned out then from what I can see, it is game over. There seems to be no way of removing it without damage as it would appear be a force fit in the case.
I may have to buy a refurbished replacement horn or get mine professionally rebuilt
Either way it is £200. |
traction39
Posted: Thu Sep 24, 2020 5:24 pm Post subject: |
On the 200 ohm setting the meter has a beep symbol. This will beep if the coil is continuous i.e there is no break in the wire / when you connect the two probes together. Check again directly on the coil- a beep will indicate a good circuit...
My penny worth.
Alistair _________________ Alistair
Riley 9 Special 1932 |
Posted: Thu Sep 24, 2020 5:29 pm Post subject: |
Note the position of the inconspicuous adjusting screw.
_________________ http://www.nostalgiatech.co.uk
Posted: Thu Sep 24, 2020 5:31 pm Post subject: |
MVPeters wrote: | It's a bit late now, Ray, since you've dismantled the horn, but a couple of times in the past I've re-tuned horns of that type.
I've just cleaned the contacts, connected 12V & gently tweaked the adjusting screw. Slowly turning the screw makes the horn rattle, then beep, then squawk & finally parp the way it should. |
Me too but I was told by the p.o that the horn was u/s. and I was intending to fully refurbish it anyway.... but I can't see any way of removing the coil - even if I could get a replacement.
Other than shelling out £200 the only other option would be to force out the coil and make one from varnished copper wire. |
Posted: Thu Sep 24, 2020 5:41 pm Post subject: |
traction39 wrote: | On the 200 ohm setting the meter has a beep symbol. This will beep if the coil is continuous i.e there is no break in the wire / when you connect the two probes together. Check again directly on the coil- a beep will indicate a good circuit...
My penny worth.
Alistair |
Good point!
Having checked it out I can tell you now there is no "beep" coming from the meter.
It looks like I shall have to buy another multi meter. |
Posted: Thu Sep 24, 2020 5:43 pm Post subject: |
Might be worth checking the battery in your multimeter.
Posted: Thu Sep 24, 2020 5:51 pm Post subject: |
Ray White wrote: |
Amazon.co.uk. 12V Horns, or your local motor spares store. |
traction39
Posted: Thu Sep 24, 2020 5:59 pm Post subject: |
It may be worth checking the continuity of the cables/probes. Plug in one of them and stick the probe end into the other socket. Repeat with the other one! This way you know the cable/ probes are OK assuming the meter is good! _________________ Alistair
Posted: Thu Sep 24, 2020 6:39 pm Post subject: |
peter scott wrote: | Might be worth checking the battery in your multimeter.
Peter |
I changed it but just the same. |
Posted: Thu Sep 24, 2020 6:47 pm Post subject: |
Peter_L wrote: | Ray White wrote: |
There are reproduction "Altette" horns available but they are not as well made as the Lucas original. Also, there were so many different Lucas versions,, which reproduction one is supposed to be authentic.?
Also, they don't last long.
( In my humble opinion, the sell out of Lucas was a betrayal of customers and share holders alike.) |
Posted: Thu Sep 24, 2020 6:51 pm Post subject: |
traction39 wrote: | It may be worth checking the continuity of the cables/probes. Plug in one of them and stick the probe end into the other socket. Repeat with the other one! This way you know the cable/ probes are OK assuming the meter is good! |
Thats a good tip..
Thank you I will try not now..............
The leads are fine. The meter just reads 0.00
Posted: Thu Sep 24, 2020 7:08 pm Post subject: |
I think it is unlikely that the coil winding is open circuit. The wire thickness is quite substantial. Corrosion may be the problem. I would spend more time investigating connection points inside the casing.
Posted: Thu Sep 24, 2020 8:27 pm Post subject: |
peter scott wrote: | I think it is unlikely that the coil winding is open circuit. The wire thickness is quite substantial. Corrosion may be the problem. I would spend more time investigating connection points inside the casing.
Peter |
I must say it would be a great relief to me if I could show that the coil is sound. I also had not expected to find a problem with the winding. I may be wrong but I would have thought if the points stuck shut they would have burned out first??
However, I have checked and cleaned the points and found nothing amiss. I tested across the points but got nothing so perhaps there is a wire broken inside the cloth covering?
I have also made sure the wires are not shorting out on the sides of the body and the connections are good....
Not withstanding the rusty diaphragm; the parts all looks to be in exceptionally good condition.
Posted: Thu Sep 24, 2020 8:34 pm Post subject: |
Red Neck "Bush Test". Stick a pin, as in a sewing pin through the insulation of one of the cables and see if you get 100% conductivity back to the soldered connection. Try it on both, if you get 100% across the pins, the problem is at the soldered joint. |
Posted: Thu Sep 24, 2020 8:53 pm Post subject: |
Peter_L wrote: | Red Neck "Bush Test". Stick a pin, as in a sewing pin through the insulation of one of the cables and see if you get 100% conductivity back to the soldered connection. Try it on both, if you get 100% across the pins, the problem is at the soldered joint. |
I could try it Pete; but those soldered connections.... they look just fine to me.
Another view from a slightly different angle:
