Rewiring
PostPosted: Fri Oct 30, 2020 1:20 am    Post subject: Rewiring Reply with quote
I have a new wiring loom for the TC rewire. This has been necessary because of the hap hazard way in which the p/o wired the car. I have removed all the wiring so I shall be starting from scratch with a new purpose made TC wiring loom from Auto-sparks.
When I rewired my 1930 Austin Swallow I only had two colours to deal with; red and black. The MG TC loom has a bewildering array of different colours...however, I am sure they will be a help when I get down to following the wiring diagram.
One question I have is that due to my decision to alter the dashboard layout there are some things like the horn push which are going to require longer lengths of wire than is available in the loom. (Incidentally, there is a separate dashboard harness) . Should I cut off short Lengths of the correct coloured wire and attach them to the horn push with a plain "joiner" to the relevant loom wires?
Or should I try and source matching multi coloured wires ? and are they available?
Short (1M) lengths of suitably rated Flecked coloured wires seem hard to locate.
Penguin45
PostPosted: Fri Oct 30, 2020 10:40 am    Post subject: Reply with quote
Hi Ray,
AUTO ELECTRIC SUPPLIES sell coloured braided wire by the metre.
I really wouldn't crimp join any extensions on if you want a long service life. It's more fiddly, but solder joints and a short length of shrink wrap sleeving over the joint will give much better and long lasting results. It's all going to be tucked up behind the dashboard, so they won't be seen.
Chris.
PostPosted: Fri Oct 30, 2020 11:24 am    Post subject: Reply with quote
Thank you very much for that Chris. I think you are right and I will be soldering connections where ever possible. I think it would make more sense (and look better) - if I have to extend wires - to do so in the same colours.
Started work last night. I have invested in a 100 Watt Weller soldering iron which is FANTASTIC!!!
As I am still waiting for the new body tub, what I plan on doing is constructing a temporary trestle straddling the chassis with a seat. That way, I can lay my old dashboard upside down and work out which wires go where.
[/i]
PostPosted: Fri Oct 30, 2020 11:28 am    Post subject: Reply with quote
Ray,
Just tell Auto-Sparks what you want extended and they will do it for you.
Art
PostPosted: Fri Oct 30, 2020 1:09 pm    Post subject: Reply with quote
47Jag wrote:
Ray,
Art
I already have the loom here. I bought it some months ago and have fitted it to the chassis and bulkhead.
I did ask them to include indicators and a reversing light wire which they have done.
Subsequently I have found I will probably need a bit more wire behind the dash.
PostPosted: Fri Oct 30, 2020 2:54 pm    Post subject: Reply with quote
Ray,
Why don't you ask them for what you need, they seem like very helpful people to me. They are in the process of making up a harness for my Jaguar just now.
Art
PostPosted: Fri Oct 30, 2020 3:32 pm    Post subject: Reply with quote
47Jag wrote:
Ray,
Art
I don't know yet what I need but it will only be short lengths to go behind the dash. I bought the loom through the Octagon Club and I know they are over worked as it is so I will take up Chris's suggestion and order the little bits I need from AES. Thanks for your input all the same.
Any help with the rewire is appreciated. Wink
PostPosted: Fri Oct 30, 2020 3:54 pm    Post subject: Reply with quote
These are really good and only pence each, keep the wiring colours correct as they make fitting and fault finding so much easier. Smile
https://youtu.be/VrQxt9ubFDA
PostPosted: Fri Oct 30, 2020 4:13 pm    Post subject: Reply with quote
I used to butt solder auto wires then shrink tube them until I found these things. Did some last year on a boat trailer excellent result.
Amazon.ca heat shrink solder butt connectors should find them at Amazon.co.uk
PostPosted: Fri Oct 30, 2020 4:54 pm    Post subject: Reply with quote
Really interesting and so NEAT !
I have never seen those before.! What else is out there that I don't know about???
PostPosted: Fri Oct 30, 2020 5:35 pm    Post subject: Reply with quote
Low melt solder can also be separated purely by dunking in hot or boiling water...
PostPosted: Fri Oct 30, 2020 6:11 pm    Post subject: Reply with quote
Ah! Wood's metal. They used to make joke tea spoons out of it.
PostPosted: Fri Oct 30, 2020 6:19 pm    Post subject: Reply with quote
Product spec's give solder minimum temp as 138 deg C.
Note that they may not always be a suitable solution if working in a confined space where a heat gun is not a suitable tool. I wonder if anyone has made a hot clamp that would go around the connector ??
PostPosted: Fri Oct 30, 2020 6:51 pm    Post subject: Reply with quote
What about one of those gas fired pencil blow torches? Good for silver soldering tiny parts together... Very directable flame too....
Or don't the connectors like direct flame?
PostPosted: Fri Oct 30, 2020 7:53 pm    Post subject: Reply with quote
A butane cigarette lighter should be enough.
(I just ordered some connectors - I'll let you know!).
2002 MINI Cooper 'S'
