heater switch with fuse.
PostPosted: Wed Dec 23, 2020 3:59 pm    Post subject: heater switch with fuse. Reply with quote
I am getting confused with this. The fitting instructions state that 'B' is the live feed to the switch. However, the fuse comes attached to a red wire which according to the instructions is for speed 2. terminal M.
Low speed is the yellow and high is orange.
C is live out to a warning light.
No colour is suggested for the live wire but I assume the fuse will be let into it somewhere.
It seems wrong to have a red fused wire in the middle of a different colour live wire.
Totally confused. Sorry.
PostPosted: Wed Dec 23, 2020 7:15 pm    Post subject: Reply with quote
I don't think that is what it means - that's just a generic fuse holder that comes with red wires already crimped to it, I bought a couple from the NEC show a few years ago.
I would imagine the fuse should go between the 12v supply and the input line / 12v feed into the switch, so that all heater speeds are fused.
PostPosted: Wed Dec 23, 2020 7:54 pm    Post subject: Reply with quote
Thanks Mike. I get easily confused with electrics. It's the same with the "B" terminal which initially I thought was B for black; then I saw it was for the live feed.
I don't know what I don't know. All I do know is that I don't know that much.
