Joined: 14 Oct 2016 Posts: 1516 Location: East Yorkshire
Posted: Sat Jan 30, 2021 11:47 am Post subject: |
Ray White wrote: | It is surprising how quickly a garage can fill with fumes. |
Like my kitchen at tea time? _________________ Dellow Mk2, 1951 built, reg 1952.
Posted: Sat Jan 30, 2021 2:52 pm Post subject: |
alastairq wrote: | Ray White wrote: | It is surprising how quickly a garage can fill with fumes. |
Like my kitchen at tea time? |
I have some lightweight trunking that clamps on the end of the exhaust and routed out the back door of the garage.
In Rick's case, the exhaust on the Talbot is somewhat non existent ...
Posted: Sat Jan 30, 2021 4:14 pm Post subject: |
Ray White wrote: | alastairq wrote: | Ray White wrote: | It is surprising how quickly a garage can fill with fumes. |
With the big garage doors open, the fumes blew down into the bottom garage so where we were wasn't all that fumey, we didn't stay in for long.
Radioman
Posted: Sun Jan 31, 2021 4:37 pm Post subject: |
Hi Rick
I am avidly following this series of videos - there's something indefinably exciting about getting something going after decades of unuse. A bit like Snow White and love's first kiss !
If you had still been struggling to start her I would have suggested running the ignition coil off a separate 12V battery, to make sure it got full whack even with the starter battery flagging. Also, the old books used to recommend pouring boiling water over an old towel, squeezing it out and laying it on the inlet manifold. Idea was to vapourise any liquid petrol. Mind you, petrol in those days was more paraffin like and sluggish to evaporate in cold weather. I expect an electric heat gun would work as well.
A bit off topic - I watched "The Dig" on Netflix, where Edith Pretty is chauffered around in a limousine with those big headlights and trumpet horns. Couldn't decide on the make (not a Talbot !) but very much the same "I'm Important" look. |
Posted: Sun Jan 31, 2021 6:23 pm Post subject: |
Radioman wrote: |
Welcome to the forum Radioman.
It looks like a Lagonda LG45 in the images I've seen.
 _________________ http://www.nostalgiatech.co.uk
1939 SS Jaguar 2½ litre saloon |
Posted: Sun Jan 31, 2021 6:53 pm Post subject: |
Radioman wrote: | Hi Rick
Thanks for joining in, glad you found the vids of interest. Another trick that I was thinking of employing, which I had to use on big Dodge years ago, was to heat the plugs up with a blowlamp before re-installing them and then trying for a start. Fortunately I didn't need to in this case.
I've been removing the old coolant hoses over the last couple of days, some of them were a trial to get off after all this time but they're off now, with no damage to adjoining pipework etc. While I'm at it, I'll clean the o/s of the engine bay a little.
Posted: Fri Feb 19, 2021 2:30 pm Post subject: |
In a bid to try running the engine for longer, I've spent time recently on the cooling system, in particular removing the many hardened old rubber hoses and the thermostat assembly, as mentioned before. This and more is covered in today's YT upload, hopefully soon I'll be in a position to have it running for longer and try the gears.
https://youtu.be/5pMNae7fO-s
Joined: 30 Apr 2013 Posts: 3125 Location: The Somerset Levels
Posted: Sat Feb 20, 2021 7:09 pm Post subject: |
Really interesting watchingvthe videos Rick, keep them coming.
I have taken some of our Hillman 80 running with the bonnet up so I will post a link to it. _________________ 1937 Ford 7w
1937 Hillman 80
1946 ERF C.I.5
1947 Hillman Minx
1955 Hillman Minx Mk8
1950 Commer R541 |
petelang
Posted: Sat Feb 20, 2021 8:57 pm Post subject: |
Good to see continued progress Rick.
In my coolant I have added Morris oils "Ankersol" corrosion inhibitor. It makes it go a vivid fluorescent green colour which is very useful for finding any weeps but it seems to do whats intended too and inhibits development of corrosion, as found when I had to drain down for a job a year or two later.
I did as you said, initially a lesser volume of antifreeze until it was clearly watertight and then increased it to near 50%..
Glad to see that big old thermostat still works after so long. Good old British engineering for those who always knock what we used to make.
8 wonder if the average BMW stat would still operate after 50 years?
Peter _________________ Daimler Fifteen 1934
Daimler V8 250 196
Daimler DS420 's x 2 |
Posted: Mon Feb 22, 2021 7:00 pm Post subject: |
I fired up the Talbot again today for another quick test, the PC was out of bounds thanks to home-schooling (and the laptop throwing a wobbler when we tried to use MS Teams on it for online lessons) so it made sense to have a little tinker outside.
The thermostat opened as it should but the top hose, while it doesn't appear to leak, doesn't have the strength to deal with hot coolant passing through it, so I'm working on an alternative to it right now.
Small steps, small steps ...
Joined: 10 Apr 2008 Posts: 2599 Location: New Brunswick. Canada.
Posted: Mon Feb 22, 2021 7:28 pm Post subject: |
Rick wrote: |
RJ |
Hi Rick, you could wrap it in Blue Tape.  |
Joined: 28 Aug 2008 Posts: 756 Location: Northern MA, USA
Posted: Mon Feb 22, 2021 8:33 pm Post subject: |
Do you have a 2" diameter spring, about 18" long, in your spring box'o'bits? _________________ Mike - MVPeters at comcast.net
2002 Mini Cooper 'S' |
Posted: Mon Feb 22, 2021 8:35 pm Post subject: |
MVPeters wrote: | Rick
Do you have a 2" diameter spring, about 18" long, in your spring box'o'bits? |
Alas no, but the plan is to come up with a more long-term solution, the top hose needs replacing anyway.
Posted: Fri Mar 12, 2021 10:58 am Post subject: |
Hi all,
Last weekend I managed to spend a lot of time working on the Talbot. It was reluctant to fire up, which was something of a surprise given how readily it had started at my previous attempt only a week or two earlier. It turned out that the old points were so worn that they struggled to fully close ever.
I also came up with an improvised solution to the top hose issue, which finally enabled me to fully fill up the cooling system and check for leaks etc elsewhere, including the radiator.
The main driver in all this though was to see if the gears would actually select, and the clutch work as intended, so that the car could be driven under its own power for the first time in 45 years. That was an exciting day.
I uploaded a new vid today covering all of this latest excitement.
https://youtu.be/fAKD7lQnkko
Joined: 01 Jul 2013 Posts: 1351 Location: nr Llangollen, north wales
Posted: Fri Mar 12, 2021 7:23 pm Post subject: |
Fantastic progress Rick, I look forward to seeing this around the shows in the future.
Kev |
-> All our old cars, vans, lorries etc |
All times are GMT + 1 Hour Goto page Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
Page 8 of 10 |
