petelang
Posted: Thu Mar 25, 2021 5:35 pm Post subject: |
A bomb detonator??
Sid
Joined: 20 Sep 2017 Posts: 76 Location: From whence cometh the mighty Lagonda
Posted: Thu Mar 25, 2021 6:40 pm Post subject: |
I trust the "big bit" that goes with it isn't under the garage.. |
petelang
Posted: Thu Mar 25, 2021 11:08 pm Post subject: |
Peter_L wrote: | I trust the "big bit" that goes with it isn't under the garage.. |
I'll be checking next visit....
Hope not. _________________ Daimler Fifteen 1934 (now sold)
Daimler V8 250 1969 |
Miken
Posted: Fri Mar 26, 2021 7:52 pm Post subject: |
Timed fuses like this are typically used for air bursting high explosive rounds just above soft targets in the open (ie people)or for illumination rounds where you want a parachute flare to deploy out from the base of the shell at higher altitudes to light up the ground beneath. |
petelang
Posted: Sat Mar 27, 2021 9:12 am Post subject: |
Well, apparently it is from a British 13 pound shell, and as Miken indicated, is a timed device intended to detonate before landing. I've not exactly figured out quite how it works.
It is a darned great heavy lump of intricately machined Brass and its just astonishing how much engineering goes into just one of what must have been millions of these things, lobbed over the trenches. In addition it seems the whole shell case was in brass too.
No wonder Britain was almost bankrupt after the war! _________________ Daimler Fifteen 1934 (now sold)
