AmusingEmu
Posted: Thu May 13, 2021 12:08 pm Post subject: My new pop project - '53 Sit Up and Beg |
Having wanted one for a long time the opportunity presented itself to buy my dream car a 1953 Sit up and Beg Ford Anglia. Body work is in great condition and has matching chassis and engine numbers along with the original paperwork.
The plan is to make this into a daily driver and have already started the process of sourcing parts etc.
Rough Plan below, I initially wanted to keep within the 8 point rule but this seems impossible to maintain while retaining all the comforts that I want for a daily driver so will now be a BIVA build which allows for quite a bit more freedom:
105e Rear Axle
105e front hubs for disc conversion
Engine swap for a mid 90s engine
Internal roll cage
seatbelts
heaters
replace floor pan
reskin roof
[/img] |
consul 57
Posted: Thu May 13, 2021 4:45 pm Post subject: |
| nice |
Posted: Thu May 13, 2021 8:39 pm Post subject: |
So the vacuum wipers are not staying then?  |
Posted: Thu May 13, 2021 10:29 pm Post subject: |
No reason not to run the vacuum wipers off a modern engine.
Posted: Thu May 13, 2021 10:43 pm Post subject: |
I wonder how the narrow wheels and cross ply tyres will handle all that extra power in the corners? ... or is that what the roll cage is for?  |
Posted: Thu May 13, 2021 11:20 pm Post subject: |
| peter scott wrote: | No reason not to run the vacuum wipers off a modern engine.
Peter  |
The roll cage tubing could also serve as a Vacuum Reservoir.  |
Posted: Fri May 14, 2021 2:27 am Post subject: |
Somebody has to say it:
If it's as largely original as it appears to be, I'd leave it alone. _________________ Mike - MVPeters at comcast.net
2002 MINI Cooper 'S' |
Posted: Fri May 14, 2021 8:43 am Post subject: |
| MVPeters wrote: | Somebody has to say it:
If it's as largely original as it appears to be, I'd leave it alone. |
If it were a basket case then I would have no qualms about it but it's not my car so not by business. |
Joined: 23 Nov 2007 Posts: 4263 Location: South Cheshire
Joined: 20 Aug 2008 Posts: 1475 Location: Netherlands
Posted: Fri May 14, 2021 11:43 am Post subject: |
| Rick wrote: | | is that an old Volvo I spy in the background? |
It does not have the typical sagging top rear door window. Also the front wheel arch in combination with the wheel does not seem Volvo.
Something American? _________________ a car stops being fun when it becomes an investment |
Vulgalour
Posted: Fri May 14, 2021 9:39 pm Post subject: |
| Ford Falcon wagon from about '62 maybe. Has that sort of look about the front fender. |
AmusingEmu
Posted: Mon May 17, 2021 2:49 pm Post subject: |
| Ray White wrote: | I wonder how the narrow wheels and cross ply tyres will handle all that extra power in the corners? ... or is that what the roll cage is for?  |
they will be banded to allow some extra grip and a better ride overall or at least that is the aim |
Posted: Mon May 17, 2021 10:48 pm Post subject: |
| AmusingEmu wrote: | | Ray White wrote: | I wonder how the narrow wheels and cross ply tyres will handle all that extra power in the corners? ... or is that what the roll cage is for?  |
Sorry ... but what is "banded"? |
Minxy
Joined: 22 Sep 2010 Posts: 273 Location: West Northants
Posted: Mon May 17, 2021 11:15 pm Post subject: |
| Ray White wrote: | | AmusingEmu wrote: | | Ray White wrote: | I wonder how the narrow wheels and cross ply tyres will handle all that extra power in the corners? ... or is that what the roll cage is for?  |
The wheel is cut in half and a ‘band’ of metal welded in to make the wheel wider while still looking stock from the side. _________________ Hillman minx convertible. Lanchester LD 10 |
