1948 Ford Prefect E93A
Goto page Previous  1, 2
PostPosted: Fri Dec 31, 2021 7:32 pm    Post subject: Reply with quote
Hi Rick. Please can you check for me that the radiator grille is not actually brass?
You may just be pleasantly surprised.
Yes it is brass.
Rick (OCC Admin)
PostPosted: Fri Dec 31, 2021 8:05 pm    Post subject: Reply with quote
Happy New Year! Smile
PostPosted: Fri Jan 14, 2022 12:25 pm    Post subject: Reply with quote
Spent a little time over Christmas and New Year working on the Prefect in the garage. Putting the fuel pump back together took a couple of attempts before it worked correctly off the car, but once it felt like it was operating with sufficient ooomphhhh I re-fitted it. Priming up took a couple of goes as initially it wasn't keen on functioning, but by rigging up a temporary fuel feed to run the engine off, with the pump's outlet disconnected, forced fuel through into the pump.
This and other tinkerings are covered in today's upload: https://youtu.be/SJhXN7ZcUiI
Rick (OCC Admin)
PostPosted: Sun Jan 16, 2022 7:56 pm    Post subject: Reply with quote
This afternoon was spent underneath the front of the Prefect, scraping & chipping away decades of caked-on mud. Not the best fun in the world but quite satisfying in a way, next little job I think will be to pull the front drums and have a peak inside. It'll also give me an opportunity to replace the rubber dust covers that protect where the brake cables pass through the backplates.
Rick (OCC Admin)
Page 2 of 2
